Best DIY Router Lift?
Forum topic by Sam posted 12-10-2012 02:46 AM 38974 views 7 times favorited 12 replies Add to Favorites Watch
View Sam's profile
30 posts in 2289 days
12-10-2012 02:46 AM
Topic tags/keywords: diy router lift router lift woodgears ibuildit stumpy nubs stumpynubs plan online question
I want a router lift, but lack the technical skill to create one of my own that I feel would be as good as ones that people are selling plans for online. Can anyone give me first hand experiences with making these and their performance as well as benefits and drawbacks? I want one that is easy to build, accurate, and reliable. The ones that I’m checking into are: – Tilting router lift – – Router lift – – MicroAdjustable router lift –
Any others out there that you would recommend? I plan to pick one and build it over the next week.
-- -Sam
12 replies so far
View Peter Oxley's profile
Peter Oxley
1426 posts in 3809 days
#1 posted 12-10-2012 02:53 AM
I love the one I made from Shop Notes plans. Every time I use my router table, I wonder how I lived with a fixed-base setup. I think it’s most similar to Stumpy Nubs’ design.
Click for details
View ,'s profile
2387 posts in 3481 days
#2 posted 12-10-2012 03:05 AM
Is there any issue with using one of the ,any routers offered on the ,market that offer above table adjustments included with the bases. We run a friend and a Milwaukee, both have excellent adjustment features for router table use, I believe other router mfg such as Triton include the features with their routers as well. If I am not mistaken, our pc890 has these features as well. With router table adjustment features so readily available for free with many router mfg, I see using an accessory lift option as being unnecessary work and cost.
View Sam's profile
#3 posted 12-10-2012 03:10 AM
I already have a router, but it does not have that feature. Would be nice though… :)
-- -Sam
View DKV's profile
3940 posts in 2438 days
#4 posted 12-10-2012 05:42 AM
Send a pm to b2rtch. He built one not long ago using a jack. I am sure he’ll help you.
-- This is a Troll Free zone.
View Cole Tallerman's profile
Cole Tallerman
392 posts in 2119 days
#5 posted 12-10-2012 03:28 PM
+1 on the shop notes plans. I first saw it on woodworking for mere mortals with Steve Ramsey. I was going to build the woodgears one but I wanted the motor enclosed for dust collection and then the crank wheel would be blocked. I like the simplicity of it and it can be adjusted from atop the table
View Sam's profile
#6 posted 12-10-2012 03:53 PM
Does anyone know where I can purchase the plans from?
Edit: found their website,
-- -Sam
View Sam's profile
#7 posted 12-10-2012 04:02 PM
Well… That was no help. No plans for a router lift! Anyone know where I can get a copy of the plans?
-- -Sam
View horsch's profile
42 posts in 2599 days
#8 posted 12-10-2012 04:02 PM
Here’s one, by American Woodworker I found a while back. It’s free and has pretty good instructions.
Peter Oxley
#9 posted 12-10-2012 04:48 PM
@ Jerry – the problems with most fixed-base-with-through-table-adjustment routers are:
1) You still have to reach underneath to clamp/unclamp the base
2) Setting the clamp usually moves the router some amount, wrecking any precision set-ups
They’re better than nothing, but I don’t know of any that compare favorably to a lift.
@ MrSam – You might be able to find a back-issue of ShopNotes #121 on eBay.
View StumpyNubs's profile
7572 posts in 2735 days
#10 posted 12-14-2012 11:03 PM
When I designed my router lift I chose ball bearing drawer slides instead of the bronze bushings that others use because they run smoother. In my experience building jigs (which is extensive) I have found that bronze bushings tend to bind when used in a linear application. They are intended to be used with the shaft spinning inside them, not sliding up and down. This problem is greatly increased when you try to run more than one either parallel to each other, like in those photo above, or even on the same shaft. It is EXTREMELY difficult to properly align the two so one doesn’t bind the other.
I am not saying my design is best. I am just saying I personally don’t like bronze bushings for sliding mechanisms.
Whatever you choose, you’re going to love having a lift on your router!
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications:
View nkawtg's profile
272 posts in 1185 days
#11 posted 12-22-2014 10:27 PM
If anyone is interested, I was looking for ShopNotes #121 router lift and found it for sale at
I like this design so I think I’ll give it a whirl
View Rayne's profile
787 posts in 1474 days
#12 posted 12-22-2014 11:58 PM
+1 on the Shopnotes router lift. The link provided by nkawtg is good as that’s where I bought mine from. I also followed through with Steve Ramsey’s design on the router table and used the Shopnotes plans for the lift. It was a fun build and am glad I have it as it has expanded my skills dramatically in building and using it.
