Use bandsaw and hand planes in place of thickness planer?
Forum topic by mak posted 12-10-2012 12:45 AM 4258 views 0 times favorited 14 replies Add to Favorites Watch
View mak's profile
mak
29 posts in 2134 days
12-10-2012 12:45 AM
The only power tool I currently own is a bandsaw. I also have been using a couple of hand planes but am finding it time prohibitive to get the stock to the right thickness using the planes I currently own. Would it be possible to smooth one face and then resaw the piece a little proud of the desired thickness and then smooth the resawed face? I’d like to get by with what I currently own in the most efficient manner possible.
14 replies so far
View ksSlim's profile
ksSlim
1281 posts in 2974 days
#1 posted 12-10-2012 12:51 AM
Yep, it works fine at my place.
Depending on the BS blade, how much work I have with the plane.
Saw early, planes make little noise to bother the neighbors later in the day/evening.
-- Sawdust and shavings are therapeutic
View Brandon's profile
Brandon
4152 posts in 3035 days
#2 posted 12-10-2012 12:52 AM
That method is possible, especially if you plan on taking off a lot of material. If you purchase a scrub plane, you can also plane down the material much faster before smoothing it out.
-- "hold fast to that which is good"
View mak's profile
mak
#3 posted 12-10-2012 12:58 AM
I am taking off 1/8 to 1/4. A scrub plane is on the wish list but not in the cards in the near future.
View Don W's profile
Don W
18879 posts in 2652 days
#4 posted 12-10-2012 01:00 AM
What do you currently have for planes?
View mak's profile
mak
#5 posted 12-10-2012 01:49 AM
A low angle jack and a low angle block are the planes currently in the arsenal. If I get even a little aggressive with the low angle jack I end up chipping off pieces of the edge of walnut and maple when I plane perpendicular or diagonal to the grain. If I back the blade off, I can avoid this but I am taking very thin shavings. The low angle jack works like a dream for smoothing and planing with the grain. At this point I am very good at smoothing both faces but downright terrible at removing enough wood to get the stock down to the right thickness. I have also been successful ripping and resawing thin consistent widths on the bandsaw.
View David Kirtley's profile
David Kirtley
1286 posts in 3082 days
#6 posted 12-10-2012 03:43 PM
The way you mentioned, will work but once you have tried a scrub, you will be amazed at how efficiently it will remove wood. If the budget doesn’t allow, you can hack together a Krenov style plane with a block plane iron with a big camber. A cheap block plane iron is like $3 at HD. Shouldn’t be too much of a barrier. Nice wide mouth. This is not a precision tool we are talking about.
bandit571
20723 posts in 2767 days
#7 posted 12-10-2012 04:17 PM
I got a H-F #33 plane that cost about $9, maybe $10. I re-ground the iron into an 8” radius camber. Mouth was plenty large enough, so now, thanks to Stumpy Knubs and his little video, I have a #3 sized scrub plane.
seen here, working down some Beech…..
View Loren's profile
10477 posts in 3732 days
#8 posted 12-10-2012 04:22 PM
Sure, you can do it, and get some great exercise
in the process.
I sometimes use a handheld electric door planer to
flatten and thickness wide boards. Quicker and
less sweaty than using a scub plane.
View pintodeluxe's profile
pintodeluxe
5736 posts in 2897 days
#9 posted 12-10-2012 04:28 PM
The funny thing about that is a good set of hand planes will set you back more than a used 13” planer. Eventually, you will want both.
For panels wider than my planer, I take them to a local wood shop with a 50” oscillating drum sander.
View shampeon's profile
shampeon
1775 posts in 2267 days
#10 posted 12-10-2012 04:56 PM
Bandit is on it. That cheapie HF is perfect for a scrub, and you will wonder why everyone doesn’t have one.
View Dave's profile
Dave
11429 posts in 2924 days
#11 posted 12-10-2012 05:45 PM
Any cheap plane, used or new is a great donor for a scrub.
View mak's profile
mak
#12 posted 12-12-2012 12:34 AM
What is the easiest way to get a 3 inch camber on a cheap plane if I don’t own a grinder? The coarsest water stone I have is 220.
View MonteCristo's profile
MonteCristo
2099 posts in 2273 days
#13 posted 12-12-2012 01:25 AM
Grinders are dirt cheap these days, although they probably won’t take really heavy use. Hard to get by without one if your time is worth anything. Same goes for a thickness planer. Obviously it’s possible to do without; just a matter of how much you are willing to suffer / do it the old way.
Don W
#14 posted 12-12-2012 01:27 AM
Send it to me with a $5 bill (return shipping)
