Cut Nails?
Forum topic by GuyK posted 164 days ago 310 views 0 times favorited 7 replies Add to Favorites Watch
View GuyK's profile
GuyK
346 posts in 2249 days
164 days ago
Topic tags/keywords: hardware cut nails question
I have projects on the list of ” Things to make ” and would like to use cut nails. I have used some in the past to make wooden boxes but have not used them much. Does anyone have tricks or thoughts on using them? Also from where did you purchase them?
TIA
-- Guy Kroll www.thelandsathillsidefarms.org
7 replies so far
View Smitty_Cabinetshop's profile (online now)
Smitty_Cabinetshop
6391 posts in 788 days
#1 posted 164 days ago
I have a stash of old ones, pulled in my youth. Tremont Nail is a source, and they ship…
-- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive
View paratrooper34's profile
paratrooper34
699 posts in 1121 days
#2 posted 164 days ago
Guy, you can purchase cut nails from the Tremont Company in Massachusetts. A google search will return the result. You can order over the internet or call them.
The trick with cut nails is to orient them correctly with respect to the grain. They are wedge shaped and will damage your project if oriented wrong. Oriented correctly, they will hold better than modern nails (at least better than the ones with out a surface applied adhesive.
-- Mike
View Arminius's profile
Arminius
219 posts in 1973 days
#3 posted 164 days ago
Your pilot hole is never big enough. Remember that they are wedge-shaped, so you need to pay careful attention to grain orientation.
Lee Valley carries them.
12064 posts in 1510 days
#4 posted 164 days ago
the big box stores carry them in a couple of sizes
just need to check carefully there
things are hard to spot sometimes
i run the width with the grain
across they act like wedges
and can split the wood
View Ted's profile
Ted
1400 posts in 381 days
#5 posted 164 days ago
Use a tapered drill bit to predrill. Other than that, ditto what the others said.
-- I'll grow up when ketchup bottle farts stop being funny.
View Grandpa's profile
Grandpa
2380 posts in 845 days
#6 posted 164 days ago
I got some at my local ACE hardware store. They should be able to order them if they don’t stock them.
View GuyK's profile
GuyK
#7 posted 164 days ago
Thanks for the info. I have looked at Tremont, they seem to be the way to go for selection.
