Sharpening stones
« back to Hand Tools forum
Forum topic by Tag84 posted 190 days ago 482 views 0 times favorited 8 replies Add to Favorites Watch
View Tag84's profile
Tag84
473 posts in 852 days
190 days ago
Hi everyone,
I just ordered a japanese waterstone for my japanese chisels, a 2 sided one. One side is 1000 grid, and 4000 on the other side. My question is, does 4000 or 6000 grid make alot of difference or will 4000 do fine?
And can i use mineral oil on the stones instead of water?
Thanks in advance!
-- -Thomas -
8 replies so far
View Loren's profile
5023 posts in 1844 days
#1 posted 190 days ago
4000 is fine to get started with. 4000 hones shaving sharp.
Your constraint will be your skill at honing more than the
stone’s grade. Anything 4000 and above is an excellent
finishing stone.
I recommend getting a naugura stone to remove glazing and
speed up your honing. Without one, the polishing stones
clog up pretty quick.
Do not use mineral oil on the stones.
View waho6o9's profile
waho6o9
3058 posts in 773 days
#2 posted 190 days ago
Hence the name water stones.
You’re going to love sharp cutting tools.
Good call Thomas.
Tag84
#3 posted 190 days ago
Thanks alot Loren, The naugura stones are used to rub the polishing stones clean?
Waho, i will ! :)
-- -Thomas -
View DocSavage45's profile
DocSavage45
3017 posts in 1038 days
#4 posted 190 days ago
There ae stones for oil. Been around for a long time. There is a whole process that should be adheard to with the water stones. You can check out you tube or Liam Neilson has put out a book on sharpening. I’d suggest getting as much information as possible before using the stones. ???? I finally figured out the safest cutting tool is a sharp one. LOL! Hope you take less time than me to figure it out.. :-)
-- Cau Haus Designs, Thomas J. Tieffenbacher
#5 posted 190 days ago
They make a milky slurry on the stone’s surface. It’s supposed
to make the edge better but I think the major advantage
is it makes stone maintenance easier.
View paratrooper34's profile
paratrooper34
699 posts in 1148 days
#6 posted 190 days ago
Tag, welcome to the world of water stones, which I also use. The 4000 “grit” works well. Somewhere down the road you may want to invest in an 8000 grit. For honing, I use 1000, 4000, then 8000. When I first started, I did not use the 4000 and got by just fine without. I got a good deal on it so now I use it. Books that I read on sharpening suggest using 8000 to 12000 for final polishing.
I tried the Nagura stone a couple of times, I noticed no difference in performance by using it. Maybe you will have different results?
I highly suggest you use something to keep your stones flat. There are some out there that try to use the whole stone when sharpening to avoid dishing it out, but I find it is much easier and more practical to use something to keep the stones flat. I have the Shapton diamond glass lapping plate (which is expensive as hell. Luckily I got mine for a hell of a deal a couple of years ago). A less expensive alternative is a diamond stone. Either way, you are going to want something to keep them flat. Water stones abrade quickly and will dish out big time, especially if you are using them a lot. When they dish out, they will mess you up and give lousy results on your blades. Diamond stones are not cheap either, but you will be happy with flat stones.
Good Luck!
-- Mike
View live4ever's profile
live4ever
980 posts in 1206 days
#7 posted 190 days ago
4000 is fine, but you can get a sharper edge by stropping afterwards. It’s cheaper than adding another stone to your arsenal. Next time you are placing a Lee Valley order, make sure to drop a green polishing compound bar ($10) into your cart. Rub it like a crayon on some MDF (or leather glued to a substrate) and use like a stone (except only with backward strokes). One bar will last you a lifetime.
Tag84
#8 posted 190 days ago
thank you all so much! great tips.
-- -Thomas -
