Help with an applewood stump
Forum topic by Jon1094 posted 12-09-2012 10:24 AM 1184 views 0 times favorited 5 replies Add to Favorites Watch
View Jon1094's profile
Jon1094
41 posts in 2204 days
12-09-2012 10:24 AM
Picked up this applewood stump a few months ago and am going to form a base for a live edge coffee table. I’ve never worked with live edge before and cant find a definitive answer. I need to strip the bark and first layer from this stump and then finish it.
The top will be finished with a coat of shellac and then bar epoxy. For the stump I’ve read that I should use a wire wheel. Some say a belt sander, others say a chisel, still others say rotary rasps. Any advice? And should I finish the stump with shellac and laquer?
Thanks!
5 replies so far
View Bagtown's profile
Bagtown
1739 posts in 3729 days
#1 posted 12-09-2012 10:33 AM
Me? I’d start with a hand wire brush and go slow.
I think a belt sander would be a mistake as it would sand away soo much, too fast.
Depends on how old (dry) it is too.
I find dryer pieces the wood has usually shrunk a little and the bark is easier to peel away.
If it’s going to be a piece of furniture, I would bring it indoors and let it settle down for at least a few weeks before I touched it.
Great piece of wood. IT will make a beautiful base.
Good luck.
Mike
-- Mike - In Fort McMurray Alberta
View MonteCristo's profile
MonteCristo
2099 posts in 2187 days
#2 posted 12-09-2012 06:02 PM
Wire wheel sounds the most promising. I guess it depends a bit on what you want the surface to look like in the end. A belt sander sounds pretty unlikely to me.
View jaykaypur's profile
jaykaypur
4017 posts in 2407 days
#3 posted 12-10-2012 02:39 AM
Like I said in my message to you…...I would use hand held brushes and then a flap-wheel sander. Most importantly, use whatever will work best for you. You’ll know. Keep on, keepin’ on. You’ll do fine.
-- Use it up, Wear it out --------------- Make it do, Or do without!
Bagtown
#4 posted 12-10-2012 02:42 AM
What Jay said.
View Nomad62's profile
Nomad62
726 posts in 2957 days
#5 posted 12-13-2012 11:34 PM
I use a pressure washer, it works very well on the bark and soft underlayers; any steel brush will leave its mark on the wood surface once you get there, so be careful.
