I'd like to make a beautiful height adjustable table
Forum topic by mazzy posted 12-08-2012 02:49 PM 9019 views 0 times favorited 7 replies Add to Favorites Watch
View mazzy's profile
mazzy
56 posts in 2549 days
12-08-2012 02:49 PM
Does anyone know where I could get:
1. the necessary hardware which would raise and lower a table to position
2. plans to make such a table
This would be a dining room type coffee table which could covert into a raised table for eating in front of the TV. I’ve seen some great looking ones on
http://marinetablesinc.com/collection/category/high-lows
and could probably think my way through the plans and construction, but just don’t know where to get the raising and lowering hardware.
Thanks,
Mazzy
-- Mazzy, San Francisco Bay Area, http://www.woodworkwonders.com
7 replies so far
View huff's profile
huff
2828 posts in 3255 days
#1 posted 12-08-2012 04:17 PM
Going to the link you have, it looks like all they use is an electric lift like you can get for mounting a TV in a cabinet. There’s a number of companies that make those lifts you can find on line. They are not cheap.
Auton is one manufacturer, but they make those lifts for TV, sewing machines and a number of other uses depending on the weight and height you are wanting.
-- John @ http://www.thehuffordfurnituregroup.com
View Lee Barker's profile
Lee Barker
2170 posts in 2820 days
#2 posted 12-08-2012 05:55 PM
Rockler has an either-or piece of machinery that’s manual.
(sidebar: our daughter found one of these tables at a thrift store for ten bucks. Bargain of the century.)
Hafele has a mechanism that is more for desks but might inspire.
Kindly,
View MrRon's profile
MrRon
4722 posts in 3213 days
#3 posted 12-08-2012 06:00 PM
I don’t know who makes them, but table raising mechanisms are used in hospital furniture, like bedside tables.
mazzy
#4 posted 12-11-2012 01:19 PM
Thanks…I started following your ideas and the internet led me to
http://www.springfieldgrp.com/
Merry Christmas
Mazzy
runswithscissors
2728 posts in 1995 days
#5 posted 12-12-2012 03:38 AM
I have cannibalized and used trailer tongue jacks in 2 projects. First was a stock support for a saw or planer outfeed. Required turning it upside down and making folding tripod legs. Works great, and is the most solid stock support I have seen. Second was a folding stand for a Ryobi BT3100 I used to have. Turned the crank to make it go up or down. It worked, but was way too complicated for little benefit. I have a habit of doing goofy projects like that. Sometimes I do those things just to see if I can. One advantage of the trailer jack is it is very robust and not at all flimsy. I picture your pedestal table stand as having a socket in the center of your compass rose (which has a circular outer rim) and then you crank it up or down. Stow the crank beneath a handy hatch or behind the setee. Anyhow, just some ideas to let you play with possibilities. Trailer jacks come in top crank and side crank. Often under $20 at HF.
mazzy
#6 posted 12-12-2012 01:22 PM
Wow…great idea. I like inexpensive :>)
Thanks,
Mazzy
mazzy
#7 posted 12-12-2012 01:40 PM
I looked at the HF jacks. I can see that they have incredible vertical support http://www.harborfreight.com/3500-lb-capacity-drop-leg-trailer-jack-3961.html. If I were to weld an extended base and also a top flat plate to support the table top, would it allow much sideways movement?
Mazzy
