Confused about "Shaker" Style
Forum topic by Ben posted 12-08-2012 04:32 AM 1713 views 0 times favorited 17 replies Add to Favorites Watch
View Ben's profile
Ben
386 posts in 3006 days
12-08-2012 04:32 AM
So I’ve read about and seen pictures of supposed “Shaker” cabinets.
Some sources calim one of the main elements in the Shaker style is the flat panel door.
But just now I came across the Lonnie Bird “Historic Shaker Set” that produces a raised panel door!
Can raised panels by used in the true Shaker style?
17 replies so far
View ShaneA's profile
ShaneA
7038 posts in 2747 days
#1 posted 12-08-2012 04:35 AM
Hmm, I have always associated shaker style with flat panels. But, I guess rules are meant to be broken.
View David Craig's profile
David Craig
2137 posts in 3257 days
#2 posted 12-08-2012 04:39 AM
I think some of the confusion might be that some folks will equate shaker furniture with mission furniture. Mission is the style most commonly associated with flat panels and simple lines. Shaker style may be simple but they are different from missionary and will use raised panels.
View bandit571's profile
bandit571
21314 posts in 2832 days
#3 posted 12-08-2012 04:41 AM
There were some “raised panels” to Shaker styled work, in fact a Cedar Chest i built awhile back had those style of raised panels. I did mine on the tablesaw, with the second cut being about 15 degrre tilt of the blade. All this does is create a better shadow line.
Not much of a Raised panel effect. Shakers liked thing very plain, with as little “adornment” as possible.
Rick Dennington
6179 posts in 3343 days
#4 posted 12-08-2012 04:54 AM
Basically the Shaker moto was ” form follows function”.....they didn’t like gawdy style furniture and fixtures..They were a simple people with a simple lifesyle, thereby building simple furniture. Shaker style furniture is my favorite to build, plain and simple…....!!
-- " It's a rat race out there, and the rats are winning....!!"
View bondogaposis's profile
bondogaposis
4996 posts in 2500 days
#5 posted 12-08-2012 05:07 AM
Many shaker pieces use flat panels, but there are exceptions. Here is one from a book I have.
-- Bondo Gaposis
View Ben's profile
Ben
#6 posted 12-09-2012 01:27 AM
Thanks Bondo.
That looks awesome.
Pretty close to the Lonnie Bird set, I reckon.
Still trying to decide between flat panel or raised panel.
117239 posts in 3726 days
#7 posted 12-09-2012 02:00 AM
View Ben's profile
Ben
#8 posted 12-09-2012 02:05 AM
Thanks a1. I’ll check them out.
Looking at the Lonnie Bird Set, can’t find any info as to whether or not the bearing for the coping cutter can be removed to make extended tenons.
What do you guys think?
#9 posted 12-09-2012 02:11 AM
If your talking about a router bit ,it may work. Not sure a photo or link might help.
View Ben's profile
Ben
#10 posted 12-09-2012 02:13 AM
View Wdwerker's profile
Wdwerker
333 posts in 2382 days
#11 posted 12-09-2012 02:15 AM
Some of the old shaker pieces I have repaired had the raised panel on the back or inside. The panel raise is done to fit the panel into the frame or drawer bottom, not for decoration.
-- Fine Custom Woodwork since 1978
#12 posted 12-09-2012 02:18 AM
It looks like the smaller router bits are for cope and stick.
View Ben's profile
Ben
#13 posted 12-09-2012 02:20 AM
Yes, they are Jim.
But I would never rely on a stub tenon in a door holding a 5/8” thick panel. I would want a longer/full length tenon, so I’m wondering if that cope cutter can do that. I’ll call Amana on Monday.
#14 posted 12-09-2012 02:33 AM
Good thinking ,even though I’ve had cope and stick doors hold up for years ,now I add loose tenons in them.
Wdwerker
#15 posted 12-09-2012 02:47 AM
I use a domino in the corners of oversize raised panel doors. Cut right through the cope and stick joint. 6mm is real close to the thickness of the tongue on the cope. I make my own domino stock to fit the widest setting and cut them to fit the deepest plunge possible. You can use a hollow chisel mortice bit in your drill press to acheive the same thing.
A 16” by 42” raised panel door in my kitchen has held up 18 years with just glue and a cope and stick joint in the corners. No extra tenon length needed!
