inside leaking roof on my new woodshed all steel construction?
Forum topic by SCOTSMAN posted 12-07-2012 08:00 PM 3253 views 0 times favorited 34 replies Add to Favorites Watch
View SCOTSMAN's profile
5851 posts in 3518 days
12-07-2012 08:00 PM
I have the most awful condensation dripping from the roof of my new all steel workshop storage shed.I have been told that applying a few thin rolls of polystyrene insulation material will stop it how thick does it have to be any other information wood be most helpful too? I am sure it’s not a leak as the whole roof inside is dripping.Alistair
34 replies so far
View chrisstef's profile
17251 posts in 2939 days
#1 posted 12-07-2012 08:06 PM
I wonder if a small dehumidifier would help out Alistair? In terms of the pS insulation i cant imagine anythign over 1” would be needed.
Were the roof seams welded? Maybe they burnt through a small portion?
Just tossing ideas around.
View MrRon's profile
4672 posts in 3176 days
#2 posted 12-07-2012 08:12 PM
A spray-on insulation applied to the roof might work; the type used on mobile homes. Condensation is due to warm moist air striking a cold surface.
Dick, & Barb Cain
8693 posts in 4232 days
#3 posted 12-07-2012 08:15 PM
I had a friend who built a ice fishing dark house for spearing fish out of aluminum sheets.
When he lit his small heater, condensation would build up, & freeze it would melt, & drip off of the sheeting.
-- -** You are never to old to set another goal or to dream a new dream ****************** Dick, & Barb Cain, Hibbing, MN.
View Built2Last's profile
234 posts in 3410 days
#4 posted 12-07-2012 08:23 PM
This is the reason they build most storage building out of aluminum, it doesn’t do that. With steel, you would have to keep it bone dry, so I don’t think a dehumidifier would help. If it got the humidity low eoungh to stop the condensation, you lumber may get to dry. You best soulution, is to put fiberglass insulation on the top, preferebly the kind with a plastic backing like they use on Butler type buildings. I built an 80 by 88 shop with steel roofing and had the same problem, ” like a rain forest up in there”. You can also spray the foam type but here its hard to find someone to spray a small building. Good luck!!
View Don W's profile
Don W
18662 posts in 2500 days
#5 posted 12-07-2012 08:25 PM
It needs to be thick enough to keep the warmer moist air from making contact with the metal. I would suggest talking to someone who knows your climate conditions for what you need.
I think mrron is on the money but don’t know how thick it should be.
-- - Collecting is an investment in the past, and the future.
View teejk's profile
1215 posts in 2617 days
#6 posted 12-07-2012 08:25 PM
condensation issue. I was told NOT to spray foam since the steel and material expand/contract at different rates leading to pockets of moisture that will cause a premature failure of the steel. cut in gable end vents to start (warm air seeks cold air). an industrial ceiling fan (pretty cheap) would help also I think.
13598 posts in 3273 days
#7 posted 12-07-2012 08:38 PM
most old tin roofs just laid the tin on cross stringers
would rot the top of the wall plates and stringers
from the condensation thru the metal
the way to stop it
is why they put tar paper
under the metal
so the water goes out
without catching on the stringers or wall plates
like a sub-roof for the water
many old barns were so open
that it wasn’t a problem
Don W
#8 posted 12-07-2012 08:42 PM
When I built my shop I was told to plywood the roof instead of using strapping because it would prevent condensation. Its worked so far.
View HorizontalMike's profile
7749 posts in 2846 days
#9 posted 12-07-2012 08:56 PM
I’m sorry to hear that Scotsman. Is it too late to add a roof vent? On my metal shop I have an 8ft long vent along the gable. It has a chain pull to open and close the vent from the inside. Just a thought.
Similar to one of these:
404 - Not Found
2544 posts in 2902 days
#10 posted 12-07-2012 09:40 PM
Any chance you could post a photo Alistair?
There’s a number of things you could do, but without knowing the construction it difficult to know where to start.
Also, would you be able to take the roof off in the spring or are you trying to avoid that?
#11 posted 12-07-2012 10:11 PM
was thinking the same thing Renners…without knowing the structure it’s hard to make suggestions. Cheapest solutions though would be to get the warm moist air outside (warm air moves to cold air) via gable vents or drive it back down via fan(s).
surprised he doesn’t have a ridge vent on the top (pretty much code now I think)...I have it in my steel building along with ventilated sofitts that creates an automatic air flow.
View juniorjock's profile
1930 posts in 3698 days
#12 posted 12-07-2012 10:21 PM
Lots of good stuff here. I’ve had the same problem. Cold meets heat = condensation. I installed some R13 insulation and I think that has taken care of it. I do pull it out in a couple of places to check it every now and then. Just wondering if a vapor barrier would help or would that be worse because its on the paper side of the insulation??
#13 posted 12-07-2012 10:28 PM
You may be on to something there. Insulation will sure help minimize temperature fluctuations inside, but one still needs to vent air on those days of extreme variation. I think I am using something called Solartex, or the like, on my shop. It is only 1/4in thick, has a vapor barrier, a radiant heat barrier, and 1/4in of fiberglass insulation. In south Texas this is perfect! In the middle of winter I can heat my 24×30 shop with a single 1000w baseboard heater. I get up to mid-60s within a couple of hours.
View DrDirt's profile
4421 posts in 3675 days
#14 posted 12-07-2012 10:36 PM
Good Points, I have seen best results on metal buildings (Morton is the big company here in Kansas) but there are others, is to go with the spray on foam, as there no water trapped anywhere.
Allistair didn’t mention what he was using for heating. If it is kerosene or Propane, there is a lot of water there. So an option depending on how warm you like it, and the kwHr rate for electricity is to use an electric heater.
View SASmith               's profile
1850 posts in 2919 days
#15 posted 12-07-2012 10:43 PM
Around here most pole barns have something like this to prevent condensation. It is less than a half inch thick. Not sure of the R factor (low I’m sure) but it does prevent condensation.
It is typically installed between the purlins and the roof metal.
-- Scott Smith, Southern Illinois
showing 1 through 15 of 34 replies
