bandsaw tires
Forum topic by MrsN posted 12-07-2012 07:50 PM 2117 views 0 times favorited 5 replies Add to Favorites Watch
View MrsN's profile
MrsN
987 posts in 3765 days
12-07-2012 07:50 PM
I have a couple of 10” delta bandsaws that are no longer in production, they are awesome saws (they stand up to the use of middle school kids all day every day. however the tires have worn out and need The normal places that I order parts from doesn’t have any tires. do you have any reccomendations on where to buy tires?
5 replies so far
View OnlyJustME's profile
OnlyJustME
1562 posts in 2616 days
#1 posted 12-07-2012 08:08 PM
Hi MrsN.
I just recently replaced my 10” Delta HomeCraft tires with urethane tires. The best price i found was from bandsaw-tire-warehouse on ebay. Just be sure to get the correct width. The 10” replacements i ordered were about 3/32” narrower than the groove in the wheel but since the blade rides the center, i didn’t worry about it. He also sent a tool to help install them and that wasn’t even listed as part of the deal. I’m happy with them.
Hope this helps.
-- In the end, when your life flashes before your eyes, will you like what you see?
View KnotCurser's profile
KnotCurser
2031 posts in 3307 days
#2 posted 12-07-2012 09:24 PM
MrsN.,
This might not tell you where to BUY some, but Matthias Wandel very recently created a youtube video about reconditioning an old/cheap benchtop bandsaw.
He wound up making his with electrical tape – no kidding!
If you don’t know about Matthias, he’s a VERY smart woodworker who has devised all sorts of tools/jigs/etc….
Here’s his youtube channel – the video you would be most interested in is currently the most recent.
http://www.youtube.com/playlist?list=UUckETVOT59aYw80B36aP9vw
Good luck with your search/solution!
-bob
-- Robert Rhoades WoodWorks / Email: rrww@rhoadesclan.com / www.rhoadesclan.com
View dhazelton's profile
dhazelton
2805 posts in 2535 days
#3 posted 12-07-2012 09:32 PM
If you search ebay for urethane bandsaw tires you’ll get tons of hits. I put some on my 1950s Sears 12 inch, and they probably came from the same seller as poster above mentions – he included a ‘tool’, which was just an allen wrench. I used the round stem of two thin screwdrivers with my foot on the bottom of the wheel. He can make any diameter and width you want. It’s a workout to put them on. About $20 a set.
Oh, and if you’re taking the wheels off (the only way to do it really) it’s a good time to inspect and/or replace the bearings.
View 69BBNova's profile
69BBNova
341 posts in 2455 days
#4 posted 12-07-2012 10:56 PM
I just checked and Timberwolf will custom make tires if that becomes your only option…
I did forget to check again (OK I’m LAZY), but I am under the impression they only make urethane tires.
View Surfside's profile
Surfside
3389 posts in 2412 days
#5 posted 12-10-2012 05:30 PM
You should check this site: www.bandsawparts.com . I suggest, you should buy urethane tires. It’s highly recommended compared to rubber tires and it doesn’t need gluing too. But be sure you select the tires that are a couple of inches smaller than the wheel for a good and reliable fit.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
