| Forum topic by oldnovice | posted 163 days ago | 1671 views | 1 time favorited | 26 replies | ![]() |
163 days ago |
Topic tags/keywords: finishing mdf sealing What if anything will protect MDF? My first inclination is shellac but I don’t really know ….. -- "I never met a board I didn't like!" |
26 replies so far
#1 posted 163 days ago |
What’s it for oldnovice? If this is going to get wet, you’d be as well using moisture resistant mdf. If it’s just for workshop fixtures and fittings you’d be ok with shellac and maybe even a topcoat depending on how far you want to go. -- Do or do not, there is no try |
#2 posted 163 days ago |
I threw together a utility bench a few years ago . The top is MDF. The tip I came across was to brush a few coats of wood glue on the surface. I know you are probably thinking. Wood glue ? It dries and forms a shiny transparent shield (much like poly) and that protects the mdf from water or moisture. So far it still looks great . |
#3 posted 163 days ago |
It depends on what use it will be assigned for….if your´re doing a kitchen cabinet for example, it´ll be nice to seal the pieces that could wet on a leaking accident…the cabinet base and the columns could be a lamineted MDF with border tape even the faces that will “glue” toghether…so the columns don´t absorve water from base surface… -- "Everyday we make it, we try to make it the best we can" Mr. Jack Daniel |
#4 posted 163 days ago |
MDO its for outdoor projects signs an such…. -- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA. |
#5 posted 163 days ago |
What are you trying to seal it from? A lot of things won’t be too hard, others impossible. I have an assembly table that is now 6 years old, made from MDF. The only thing I’ve ever put on it was a mixture of beeswax/BLO/turpentine. The only damage it has is scrapes/scratches from the work I do on it. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#6 posted 163 days ago |
There are commercial sealers avaialbale, primarily to prime the surfaces if you are intending to paint. If, from the previous replies, you are looking at sealing the edges (known as sizing) thinned down PVA (with water) will do a pretty good job. One coat should be enough but two maybe required depending on how tight you need the sealing to be. Even poly take several coats before an edge is suitable sealed. Using glue will dry out quickly too. Good luck -- No one plans to fail, they just, just fail to plan |
#7 posted 163 days ago |
I use spar varnish thinned 50/50 w/ mineral spirits. It really drinks it in and seals up nice. -- Bondo Gaposis |
#8 posted 163 days ago |
If you’re asking about the edges, it’s called gluesize. 50/50 wood glue and water, brush it on heavy, let it dry and sand it smooth. Any old sealer will protect the top, it’s the edges that are a problem. -- Sam Hamory - The project is never finished until its "finished"! |
#9 posted 163 days ago |
Sand & Sealer works great !!! |
#10 posted 162 days ago |
Depending on what I have on hand, I use either Vinyl Sanding Sealer, or Lacquer Primer. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#11 posted 162 days ago |
High end finish on MDF that’s funny! |
#12 posted 162 days ago |
I wouldn’t normally be concerned about sealing it but with the rain we have in the last few days everything in my garage feels “clammy”! The MDF in question is the spoil board on my CNC and I don’t want it to “grow” fuzz and get out of flat. It took three passes to get it flat “flat as a board” and remove about 0.045” off the top surface! I would like to keep it that flat at for a little while after all it is a spoil board and, as the name implies, it is supposed to get spoiled. I thank all that responded and since I have the primer I will use that and see what happens! -- "I never met a board I didn't like!" |
#13 posted 162 days ago |
Pat warner uses danish oil on his MDF router table and it holds up extremely well. -- He who dies with the most tools... dies with the emptiest wallet. |
#14 posted 162 days ago |
blackcherry: Actually, you’d be surprised how you can get a high-end finish to take to MDF. I can get a pretty high gloss on a lacquered top made from MDF. Smooooth and flat and shined to a mirror finish. oldnovice: I assume you don’t have a vacuum sucking through the mdf to hold your parts. If you did, I’d say to just edgeband or seal the edges with glue. That might still be a good idea to limit moisture absorption. If this were my machine, I’d leave the face raw. It’s called a spoil board for a good reason— It will get spoiled (ruined) with use. Don’t spend too much time on it. It is actually to your advantage to have a bit of friction between it and your parts. If it’s too slick they won’t hold still as well. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#15 posted 162 days ago |
If you bolted your spoil board to the table, be sure to inset the bolt heads so you have room to fly cut your board a ways before needing to replace the spoil board. If you notice it is getting rough or “fuzzy”, as you call it, you can fly cut it again with little effort. It might be a good idea to have a dedicated spoil board which has finish on it and then a disposable spoil board on top of that which can be replaced often—just a thought. -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15748 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
