Can someone tell me how this was done?
Forum topic by RussellAP posted 12-06-2012 03:43 AM 2051 views 1 time favorited 18 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3104 posts in 2522 days
12-06-2012 03:43 AM
The description says the cracks are filled with turquoise. Have you seen this done before and where do you get supplies?
Edit a couple hours later:
I have found crushed turquoise, colored sands, metal powder and gotten some of each. Also have some small tubes of epoxy and some thin and medium CA glue, plus some clear filler for larger holes.
18 replies so far
Rick Dennington
6347 posts in 3430 days
#1 posted 12-06-2012 03:54 AM
Russell:
I have seen this done before in pieces of furniture and jewelry…..There used to be suppliers of turquoise in Albuquerque, New Mexico….They make a lot of turquoise jewelry there…Look under suppliers…..I’ve seen some beautiful work done out there by Native American Indians, but it’s pretty expensive…...
-- " At my age, happy hour is a crap and a nap".....!!
View Mip's profile
Mip
453 posts in 2314 days
#2 posted 12-06-2012 04:00 AM
Some of the suppliers of turquoise has instructions and videos on how to install it in your project. Try Craft Supplies. It’s turquoise powder mixed with epoxy, I think, rubbed into the crack and sanded out.
RussellAP
#3 posted 12-06-2012 04:04 AM
@mip, That’s what I thought. I’ve been wondering if I have to crush my own rock and if it would come out blue or whatever color I want when I crush it. Mostly they look white when you crush up stones of any color.
View Ted's profile
Ted
2875 posts in 2447 days
#4 posted 12-06-2012 04:11 AM
I believe the crushed turquoise is mixed with epoxy and used to fill the cracks, then sanded smooth. Epoxy may be colored or clear. The white you see is just dust. Get the crushed stone wet and the color comes right back.
-- You can collect dust or you can make dust. I choose to make it.
13641 posts in 3577 days
#5 posted 12-06-2012 04:11 AM
a good jewelry supplier
is where i found crushed turquoise
from powder to small gravel rocks
they will have the right epoxy for it too
the best looking ones i’ve seen
add some black to the epoxy
it brings out the blue
RussellAP
#6 posted 12-06-2012 04:15 AM
I’m trying to find some course sand in several colors at the moment. I will have to get some clear epoxy. I have some walnut slabs that have beautiful rings and a crotch that needs something to dazzle. Filling it with blue shiny stuff might just do the trick.
View waho6o9's profile
waho6o9
8539 posts in 2813 days
#7 posted 12-06-2012 04:30 AM
http://www.nightowlwoodworks.com
Ask fellow LJer, Nightowl, his website is above, and his work is awesome
View RetiredCoastie's profile
RetiredCoastie
999 posts in 3419 days
#8 posted 12-06-2012 04:45 AM
I’ve used this technique before in turnings. You work in small sections at a time and build it up. I pack small amounts of stone dust or powder into the crack or void and apply CA glue and activator then add more dust
and repeat until the void is filled just above the surface then sand until flush. check out www.arizonasillouete.com
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
RussellAP
#9 posted 12-06-2012 04:55 AM
What I’d like to find is some sort of clear liquid filler that can be used on a crotch piece to fill it. I could lay the turquoise in that after it’s filled and let it dry, then finish with some CA glue or just more of the liquid filler till it’s slightly raised then sand it down.
View mrg's profile
mrg
849 posts in 3235 days
#10 posted 12-06-2012 05:10 AM
Russ,
you can get the turquoise here
How’s the turning going?
-- mrg
RussellAP
#11 posted 12-06-2012 05:24 AM
@mrg. I just went broke, but you’re gonna see some serious stuff come outa my shop.
View Nicholas Hall's profile
Nicholas Hall
352 posts in 2342 days
#12 posted 12-06-2012 05:24 AM
That’s very cool. I might have to try that…
-- Outside of a dog, a book is a man's best friend. Inside of a dog, it's too dark to read. -Groucho Marx
View Jim Finn's profile
Jim Finn
2688 posts in 3158 days
#13 posted 12-06-2012 12:32 PM
I have gotten this same effect using “Z-Poxy” and blue chalk (for chalk lines). Lots cheaper but looks about the same.
-- No PHD just a DD214 Website> craftingcouple.com
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3522 days
#14 posted 12-06-2012 02:23 PM
Take a look at this. In the comments I shared a little bit of how it was done.
http://lumberjocks.com/projects/63286
If you have questions, don’t hesitate to contact me.
-- http://shepherdtoolandsupply.com/
View woodsmithshop's profile
woodsmithshop
1364 posts in 3781 days
#15 posted 12-06-2012 02:35 PM
GOOGLE- inlace, they have all of the things you need for inlay epoxy and crushed rock.
-- Smitty!!!
