Bandsaw Blades
Forum topic by LibertyBay posted 100 days ago 214 views 0 times favorited 5 replies Add to Favorites
View LibertyBay's profile
LibertyBay
4 posts in 236 days
100 days ago
Topic tags/keywords: bandsaw blades
I seem to go through an awfully lot ob blades on my Jet 14” bandsaw. I normally use 1/4 inch blaedes because we do a lot of contour cutting (LOML uses it much more than I do). Actual running time is probably in the neighborhood of 3 or 4 hours a week.
Blades seem to last about a month or so, and break usually away from the weld. I’ve been using blades from Woodcraft Bands, which I think are by Lennox. The Olson Pro and Morse blades I’ve tried haven’t lasted any longer. I occasionally use a 3/8 or 1/2 inch blade, but never leave them on long enough to have any feel for how long they might last.
Is this degree of breakage normal? Anybody have any sugeestions to slow down my blade consumption?
View Chris 's profile
Chris
1259 posts in 527 days
100 days ago
Bob,
I was having poor performance with my blades and someone suggested I speak with the guy’s at Suffolk Machinery (MFG’s of TimberWolf blades). They took about 20 minutes or so with me talking about what I cut, how I cut, etc… then made a couple of recommendations and I have not looked back since. You might wish to give them a call; I found it to be time well spent.
I reviewed their one of their blades earlier in the year.
BTW, I too have a jet 14”.
-- Chris
View RWR's profile
RWR
24 posts in 138 days
100 days ago
Bob,
I second Chris’s take on the Timberwolf blades. They are of high quality and the folds at Suffolk Machinery
will talk with as long as you wish. Also, I would reccomend you send off for one of their blade
catalogs as it gives great instructions oh how to properly tension a bandsaw blade. I have a Rikon
14” bandsaw and it works great with the Tiimberwolf blades (I have 3’1 6”, 1/2”, and 3/4”)
Wayne
-- Wayne
View Joey's profile
Joey
229 posts in 352 days
100 days ago
if your doing alot of contour cuts, there is a possibility that your putting too much pressure on the blades when your cutting the turns. i used to have this problem cutting out spoons. I started making reliefe cuts which took alot of pressure of the blades and haven’t had near the problems since.
-- Joey, Magee, Ms http://woodnwaresms.com
View waynet's profile
waynet
22 posts in 411 days
98 days ago
You may want to try SuperCuts Bandsaw company. They are on the west coast and their website is supercutsbandsaw.com. They make a premium blade that is unbelievable and they stand behind their blades. Cutting with one of their top quality blades is like cutting butter with a hot knife. It’s a small family owned company and they will answer all your questions. 1-800-356-9918
Other than using their blades I have no affiliation with this company.
-- Wayne, Tennessee Mallard Design
View AlanWS's profile
AlanWS
4 posts in 94 days
94 days ago
Lennox makes good blade stock. If the blades are breaking away from the weld, it’s not the vendor who sold it to you, as the weld is all they are responsible for.
They should not break so frequently. I would suspect that something is putting stress on the blade in a way that should not happen. Perhaps it is cutting technique – pushing sideways or twisting. Or it could be a misalignment of guide or thrust bearings. If you back off the thrust bearing and guide blocks (both above and below the table) and run the blade, is it stable? Then bring the bearings back close to the blade without moving it forward, back or sideways.
If the thrust bearing had been too far forward, it could cause much more stress on the blade as you cut than a properly set thrust bearing.
-- Alan in Wisconsin
Bookmark And Share This Page
