| Forum topic by Eddy_1287 | posted 167 days ago | 487 views | 0 times favorited | 3 replies | ![]() |
167 days ago |
Topic tags/keywords: dust collection I’ve done a bit of research looking into dust collection products. I currently have a 14gal shop vac that would work great with the “Dust Deputy”. But I’ve heard there is a similar product out that uses the same idea but instead uses shop air instead of a shop vac. Has anyone here heard of anything such thing??? If so what is it called and where could I pick one up? |
3 replies so far
#1 posted 167 days ago |
You won’t regret the dust deputy. You can even make your own very effectively and simply. -- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com |
#2 posted 167 days ago |
A venturi based vacuum uses compressed air, blowing through a perimeter slot in the throat of a venturi to entrap a larger volume of air and suck it through the venturi. In other words, a vacuum powered by compressed air with no moving parts. Yes they exist and they do work. Often used in large industrial applications where the sparky little universal motors of standard vacuums would be hazardous. Like for sucking oil and metal chips out of a sump under a machining operation. They suck about 4 times more air than they use. So, to get a 150 CFM vacuum you need about 40 CFM of compressed air at 90 PSI. The problem is that would be like a 10 HP compressor. Still, even though they are not energy efficient, they do solve problems for specific applications.
Here is a like to McMaster Carr , one source for these machines. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#3 posted 167 days ago |
Thanks a lot for the information. I do have a pretty big compressor but definitely not one that makes 40 CFM. Mine only puts out 12.5. I still might try my hand at building one just to see it will work, but I guess that’s probably my stubborn side talking. |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3549 |
15783 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
