European hinges gap problem
Forum topic by mileskimball posted 165 days ago 638 views 0 times favorited 9 replies Add to Favorites Watch
View mileskimball's profile
mileskimball
44 posts in 180 days
165 days ago
I’m having a problem on my first time using euro hinges. It’s a face-frame installation, 1/2” overlay, 105 degree hinges.
My problem is that on the hinge side, when the door is closed, there’s a good 3/16” gap between the face frame and the back of the door. If I adjust the hinges to lessen the gap, the door binds when it swings.
Do people usually put a bevel on the hinge-side back edge of the door for clearance?
Or do you drill the big hinge hole so it’s closer to the hinge edge of the door (thus if the hinge is on the right. shifting the door to the left when closed and away from the frame when opened)? I’m already drilling the hole within 3/16” of the door edge, though, so there’s not much room there to play with. This approach also shifts the overlay so it’s not even on the 2 sides of the door, and my doors and drawers would no longer line up vertically.
This has me very puzzled. On the bottom doors, the gap is big enough for you to actually see stuff inside the cabinet, which kind of defeats the purpose.
-- Miles
9 replies so far
View pintodeluxe's profile
pintodeluxe
1733 posts in 979 days
#1 posted 165 days ago
3/16 is a bit much, but 1/8” is pretty common. My hinges can usually adjust for it. If you think about it, on the non-hinge side you will have rubber bumpers. The bumpers are about 1/8” thick too, so the gap is symmetrical.
4873 posts in 1814 days
#2 posted 164 days ago
How far in did you drill your cup holes from the edge
of the doors?
You have to get that right (23mm generally) or the
door may bind if the hole is in too far from the edge.
Also, you are using half-cranked hinges, right?
With a non-cranked hinge the overlay at 23mm is
a bit less than a full overlay, so when cabinets are
put side-by-side, there’s about 3mm between the
doors.
With a half-overlay cup hinge hole drilled at 23mm
the 3mm gap is supposed to fall in the centerline
of a 19mm melamine panel. The overlay is actually
more like 3/8”.
Easing the edge of the door should be all that is
required but if the drilling of the cup holes is
too far in, then you have a problem.
View renners's profile
renners
1879 posts in 1135 days
#3 posted 164 days ago
What thickness are the door stiles?
I haven’t used the face frame euro hinges, but on the inset (cranked) euro hinges, you run into problems with stiles thicker than 22/23mm. The edge binds when you open it if the stile is thicker than that.
Hafele.com have technical drawings on their website with all relevant dimensions for drilling etc.
-- Do or do not, there is no try
renners
#4 posted 164 days ago
^ Sorry, scratch that, I thought you had inset doors, not half overlay.
Are they the 8º crank half overlay hinges?
View DS's profile
DS
1817 posts in 586 days
#5 posted 164 days ago
Some of the inexpensive one-piece hinges (hinge and baseplate in one) have up to a 3/16” gap like that. They also have a “throw out” when they open which can cause them to bind like that too.
It’s best to use a two-piece hinge. I personally like the Blum CLIP hinge, but many others will do fine. The gap is tight and there is no throw-out so the hinge can be set with very little side clearance and it won’t conflict.
View oldnovice's profile
oldnovice
1726 posts in 1534 days
#6 posted 164 days ago
I have used the two piece and they are very “forgiving” as far as misalignment goes. You can usually get them aligned and symetrically adjusted with little effort!
mileskimball
#7 posted 164 days ago
Thanks for the responses, everybody!
The stiles are 19mm, so that’s doesn’t seem to be the problem, and the cups are inset right about at 3/16 from the door edge, so that doesn’t seem to explain it either. Sounds like the problem may be that I’m using cheap one-piece hinges. Fortunately, I’ve only made three prototype doors (out of 28 for the whole kitchen I’m redoing), so I’ll chalk this up to the price of education.
DS251, is this the kind of Blum hinge you’re talking about?
http://www.hardwaresource.com/hinges/CABINET+HINGES/European+Hinges+-+Blum+Hinges/Blum+Clip+Top+Hinges/Blum+120+Degree+Clip+Top+Hinge%2C+Straight-Arm+Style
They’re a little spendy at $2.99 each – any other brands anyone might recommend that would be a little more economical?
-- Miles
#8 posted 164 days ago
Hafele has some economical hinges that work fine.
This is an industry supplier that has prices lower, in general,
than you’ll see at retailers that serve the handyman market.
http://www.baersupply.com/baer/wg-index.jsp
View DS's profile
DS
#9 posted 164 days ago
Yes, that is the hinge I prefer. Though, you would need the winged baseplate for face frame mounting as well, so that is only part of the cost
Depending on where you live, there are several less expensive options. I would first explore a wholesale source for them to get the price down. Here's a good place to start.
Also, there are some no name brand hinges that are knock offs of this one that work just as well in most cases. Some of these get down into the $1.50 range for the plate and the hinge.
