Lathe Bench
Forum topic by Seer posted 463 days ago 283 views 0 times favorited 4 replies Add to Favorites Watch
View Seer's profile
Seer
92 posts in 541 days
463 days ago
I have an older lathe made by Craftsman in the 70’s model 113-23800 and am trying to figure how to mount it on a bench becasue the motor is a seperate unit. I have seen where it is hung upside down under the lathe on a bench or on a hinged board behind it letting the motor keep tension on it. Does anyone have any good ideas or a drawing to help me?
Thanks
Jerry
View Mark Shymanski's profile
Mark Shymanski
1555 posts in 611 days
386 days ago
Are you mounting this on a pre-existing bench or building one for the lathe?
View Seer's profile
Seer
386 days ago
I was going to build one as soon as I get the time but still unsure of how to mount the motor
View Steve2's profile
Steve2
48 posts in 469 days
386 days ago
You just described it – i have the same lathe – sits on a surface 8” or wider with the motor hanging beneath the headstock upside down from the underside of the surface with a rectangular slot under the pulley for the v-belt to pass through
-- Regards, Steve2
View Steelmum's profile
Steelmum
347 posts in 861 days
385 days ago
I also have this lathe. Mounted 2×4’s to the bottom of the lathe, then built a set of legs to mount it to. Needed to add a shelf to the bottom to add weight. An extremely early project, still haven’t changed it. Looks like crap, works just fine.
-- Berta in NC
