| Forum topic by TVT | posted 196 days ago | 644 views | 0 times favorited | 7 replies | ![]() |
196 days ago |
Topic tags/keywords: question trick clamp I am glueing up a few cutting boards and am having some issues. I have made two edge grain boards and both of them have been twisted when I pulled them out of the clamps. They were tight in the clamps and clamped from both sides. Any suggenstions on how the fix this problem or if I do have a twist what is the best way to remove it? Any help would be appreciated. Thanks -- Measure once, cut twice - you think I would learn! |
7 replies so far
#1 posted 196 days ago |
Depending no the severity of the twist, I would probably try using winding sticks and hand planes to flatten the boards. -- John, BC, Canada |
#2 posted 196 days ago |
You don’t have a lot of fancy options with the ones already glued up. You might look into the assembly process for issues because there can be several: -- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com |
#3 posted 196 days ago |
Dan has some good advice. I’d add that it’s important to make sure you have good air flow around the whole thing while it drys. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#4 posted 196 days ago |
Plus Plus on the cauls |
#5 posted 195 days ago |
This happened to me once. On a whim. I ripped it again down the middle. I flipped one side over and re-glued it so one face was completely flat. After it was glued I sanded the flat side down to make sure it was really flat and then sent it through the planer again to clean up the top. It worked well. |
#6 posted 195 days ago |
Thanks for all the helpful ideas. -- Measure once, cut twice - you think I would learn! |
#7 posted 195 days ago |
Odds are the twist is due to stress in the assembled piece. Make it flat and there is a good chance, if there really is stress in the assembled piece, that it will go out of flat again. IE you want your initial pieces to be as stress free as possible and not to introduce stress in the gluing up process. -- Dwight - "Free legal advice available - contact Dewey, Cheetam & Howe"" |
| Forum | Topics |
Woodworking Skill Share
8846 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15980 |
Hand Tools
2097 |
Jigs & Fixtures
501 |
Wood & Lumber
2907 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2777 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
