Can I use a 1/4 HP motor on a small 8" table saw?
Forum topic by Steve posted 12-04-2012 07:17 PM 2132 views 0 times favorited 11 replies Add to Favorites Watch
View Steve's profile
Steve
174 posts in 2165 days
12-04-2012 07:17 PM
Topic tags/keywords: 8 table saw craftsman motor
I have my father’s old Craftsman 8” table saw. When I try to turn it on, the motor hums but does not spin. I’m thinking it might need a new capacitor but I haven’t tested it yet. I tried spinning the shaft to get it going but that did not work. It is a 3/4 HP 3450 RPM motor and I don’t think it’s the original one.
I have a belt/disc sander that I do not use and it has a 1/4 HP 1725 RPM motor on it. If I can’t get the 3/4 motor working, do you think I could just put the 1/4 motor from the sander on the table saw? I would only use it for small pieces of wood 3/4” thick or less, so it seems like it would do the job. Would I need a different size pulley on the motor shaft to compensate for the 1725 vs 3450 rpm? Should I just try it and see if it cuts small parts ok, since I need to remove the old motor anyway? Thanks for any input and opinions you can provide.
-- Steve in Lawrenceville, GA - http://www.TheCarmichaelWorkshop.com
11 replies so far
117063 posts in 3545 days
#1 posted 12-04-2012 07:22 PM
I would think 1/4 HP would be way under powered you would need art least the 3/4 Hp the saw came with.
View Woodknack's profile
Woodknack
11486 posts in 2348 days
#2 posted 12-04-2012 07:25 PM
The worst I see happening is the motor burns up. I think 3/4” stock is pushing it for a 1/4HP motor.
View crank49's profile
crank49
4030 posts in 2939 days
#3 posted 12-04-2012 07:56 PM
No.
It’s the wrong speed also.
View MonteCristo's profile
MonteCristo
2099 posts in 2157 days
#4 posted 12-04-2012 07:59 PM
With benchtop table saws as cheap as they are today, it hardly seems worthwhile to make such an effort. Also, the 1/4 hp motor may not like the load due to the (heavy for it) blade on startup. If your motivation is to resurrect a family heirloom, I’d give it a try but don’t 1.5” hardwood on it !! Also, keep the blade really sharp !
View Bill White's profile
Bill White
4907 posts in 3929 days
#5 posted 12-04-2012 08:38 PM
And the answer is ??? NO!
Bill
-- bill@magraphics.us
Steve
#6 posted 12-04-2012 08:53 PM
Thanks everybody! I guess I won’t bother with the 1/4 hp motor. I will see if I can fix the 3/4 or find another one to get it working. I have a bigger table saw, but just wanted to see if I could get this little one going and use it for something since it’s taking up space. It would be nice to keep this one set at 45 degrees all the time, so I would need a bigger motor for that anyway. I knew this would be the right place to ask this question. :)
View MrRon's profile
MrRon
4720 posts in 3212 days
#7 posted 12-04-2012 10:29 PM
With a good sharp blade, it would work but you would have to put a larger pulley on the motor to get the speed up to the 3500 mark. I wouldn’t try cutting hardwoods or anything over 3/4”. I think if you do it, you will find the speed falling quickly to the point of stalling. I could see it being used for hobby purposes where very thin wood (1/8”-1/4”) is being cut. If you can’t fix the 3/4 hp motor, Harbor Freight has some reasonably priced motors.
View Ted78's profile
Ted78
376 posts in 1968 days
#8 posted 12-04-2012 11:29 PM
It would be underpowered for sure, but to just flat out say no it can’t be done is wrong. If your cutting small stuff, and your blade is sharp, and you don’t mind feeding the stock SLOWLY it would work.
-- Ted
View Grandpa's profile
Grandpa
3259 posts in 2644 days
#9 posted 12-04-2012 11:56 PM
I am with Ron on this. Go to Harbor Freight and lay out a few dollars for another 3/4 or 1 hp motor with the same base. You will save a lot of time since you will probably end up there anyway. I feel like an under powered saw is more dangerous. Things stop the blade of bind worse.
View dhazelton's profile
dhazelton
2756 posts in 2265 days
#10 posted 12-05-2012 12:02 AM
By the time you’ve bought a new motor you’ve bought another used saw that’s larger and more useful. It may be time to put that on the shelf as an heirloom. Those bases are nice to keep though, so save that.
404 - Not Found
2544 posts in 2937 days
#11 posted 12-05-2012 12:10 AM
1/4 hp is too weedy IMO
