Should I plane first or edge join and then plane
Forum topic by BamaCummins posted 459 days ago 819 views 1 time favorited 17 replies Add to Favorites Watch
View BamaCummins's profile
BamaCummins
54 posts in 471 days
459 days ago
Making some drawers out of poplar for a chest of drawers project, the drawers will be faced with red oak. I have 3/4 poplar that needs to be planed to 1/2 inch. Also the variable width boards have to be edge joined-glued in order to get the 8 inch width boards I need. What should I do first, edge join or plane? Wonder if the glue will hurt the planer blades? Should I use biscuits or just glue?
Thanks for all the help.
-- "I don't know, we haven't played Alabama yet." -- Vince Lombardi after being asked what it felt like to be the greatest football team in the world just after winning the '66 Super Bowl.
View PurpLev's profile
PurpLev
2752 posts in 543 days
459 days ago
I was wondering the same, but I think the planning should be part of the milling process – and should be done on each piece individually prior to glueing up – making the next step after glue up as simple as cleaning and some sanding.
Also it’s easier to mill smaller pieces then large ones – not to mention that it really depends on how large your glue up are going to be – sometimes they are larger than the planer all together. plus you won’t have to plane those glue joints – which is only a good thing…
View skeezics's profile
skeezics
198 posts in 614 days
459 days ago
face joint to get them flat then plane to thickness then edge joint with the grain. I sometimes face joint then edge joint then plane if the wood has strait grain. just glue will be fine but biskits help with alignment. you can also use culls clamped accross the boards to keep the flush with each other. I’ve never notised the glue hurting the knives. I do scrape off the exess glue before final thicknessing. the rule is you want a nice flat side to run against the fence for edge jointing. it keeps things square.
skeez
-- hey honey! watch this!
View pommy's profile
pommy
958 posts in 586 days
459 days ago
I,m with skeezics on this I,v just finished a project and i biskit my edge joints first then planned to correct thickness your knives should be fine
be nice to see finished project to
andy aka poomy
-- cut it saw it scrap it
View Catspaw's profile
Catspaw
186 posts in 710 days
459 days ago
Definitely plane after glue up. This assumes you have a planer that will handle the width. If you think you can glue them up all in the same plane and get a flat smooth surface, I’d say you were kidding yourself. Planing after is also the time saving, don’t have to think about it method. you just get it done.
-- arborial reconfiguration specialist
View jtreynoldsJTR100's profile
jtreynoldsJTR100
9 posts in 471 days
458 days ago
I’d split the difference.
Take the boards down partway to final thickness, square the edges, then edge glue. Clean up any excess glue and plane to final thickness.
I always use biscuits. They’re quick and easy, I think they add strength, and as skeez says they help with alignment
-- Jake http:/www.adirondackchairscentral.com
View James Early's profile
James Early
48 posts in 543 days
458 days ago
One thing—if you decide to plane after glue-up, make sure to orient the grain of each strip the same way. Otherwise, you would get tear-out planing in either way, because some strip(s) would always be in the wrong direction.
-- -- Jim E., Oswego, NY. Create, have fun, and work safely!
View herc's profile
herc
20 posts in 498 days
458 days ago
I would:
1. face joint
2. plane
3. edge joint one edge
4. rip opposing edge on tablesaw
Hardened glue proud of the wood will damage planer knives.
Denny Bell
http://www.bellforestproducts.com/
-- Denny, Upper Michigan
View gizmodyne's profile
gizmodyne
1675 posts in 985 days
458 days ago
Plane to the same thickness.. whatever they both hit first.
Edge join.
Plane to final thickness.
View sIKE's profile
sIKE
1094 posts in 649 days
458 days ago
I would face joint first, the edge joint. That will make the edge square to the face that you jointed. Then rip the other edge to width + 1/32, and finish off the final 32nd on the jointer. Your edges will now be parallel to each other. Then finally plane the other face to thickness, this will make this face parallel to the other face, your board will now be square.
Depending upon how picky you are you may want to face joint your inside face first then plane your outside face to thickness. If you hit some preaty figure on the outside face, as long as you are already parallel to your inside face you can flip the board over and take the inside face down to thickness.
Hope this helps.
View grumpycarp's profile
grumpycarp
232 posts in 640 days
457 days ago
I agree with gizmodyne and sIKE. And I think that biscuits on long grain joints (edge to edge) are a complete waste of time. They’re too loose fitting to be of any real value in alignment and they don’t add any strength along the joint as the glue joint will be stronger than the wood. They “might” aid in adding shear strength. Use cauls for alignment.
View YorkshireStewart's profile
YorkshireStewart
781 posts in 796 days
457 days ago
I just noticed grumpycarp’s reference to biscuits being loose. Are we talking about the same thing as in UK? Compressed beech ovals 4mm or 5/32” thick. I’ve never found them loose here. They normally need a tap with a hammer to get them started and/or pulling into place with sash cramps. I always use them in this sort of situation for accurate alignment.
-- Res severa verum gaudium - True pleasure is a serious business. http://www.folksy.com/shops/TreeGems
skeezics
457 days ago
mine fit nice and snug too. get one now and them that is thicker oe thinner but these are rare. with my old PC-556 they fit loose! with the lamello they are right. I’ve also found that certain brands of biskits are not uniform in size and run a little on the small side. I recomend lamello biskits no mater what brand cutter you use.
skeez
Dick, & Barb Cain
7036 posts in 1194 days
457 days ago
I never use biscuits in a close fitting flat glued joint either.
If your biscuits are tight, that means they’ve gathered up moisture, & causing them to swell.
I store my biscuits in a tightly sealed jar.
Biscuits aren’t supposed to be tight. The glue is supposed to make them swell.
Another thing that I’ve heard, the swelling of the biscuits
have caused raised humps along the surface, on certain wood types.
View GEORGE6149's profile
GEORGE6149
30 posts in 492 days
457 days ago
I saw once in a post that if you put biscuits that have expanded because of moisture,in the micro-wave for a few seconds,they will return to normal.
-- GEORGE
View John Ormsby's profile
John Ormsby
503 posts in 632 days
457 days ago
Biscuits will telegraph through the surface when still wet. Make sure you use a good glue, like titebond 3, so the glue becomes more stable when dry. Sanding is always necessary after using biscuits. I use biscuits, a glue joint shaper cutter, splines, and sometimes just edge gluing methods. I think you can get by just fine edge gluing when making drawer boxes.
-- Oldworld, Fair Oaks, Ca
Dick, & Barb Cain
455 days ago
This is the company that makes the biscuits for, PC, & Ryobi.
There plant is about 20 miles from my cabin.
They also sell hardwood lumber, & veneers.
BamaCummins
450 days ago
Thanks for all the input. Now I just have to decide if I want 1/2 thick drawer sides as the plan called for or make them 3/4 ” . Boy, I hate to plane away good wood, but the drawers would be a bit heavier.
