Sealing without changing tint.
Forum topic by RussellAP posted 12-04-2012 12:35 AM 1007 views 0 times favorited 9 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2254 days
12-04-2012 12:35 AM
I was wondering if there is a furniture sealer I can get that does not change the color of endgrain.
My latest project includes this curly maple which I turned the wrong way. It was a chunk of firewood but had some possibilities and some curl. Anyway, I’m left with end grain and I want to seal it but I don’t want it to turn dark on me.
Any idea’s?
9 replies so far
View WoodyG's profile
WoodyG
33 posts in 3140 days
#1 posted 12-04-2012 01:14 AM
My first thought is High Gloss spray lacquer. You will find out pretty quick and if it works then you can go
in a different direction should you not want a hgih gloss finish? I tell you I use wax alot anymore but I seal
and put a finsh on first then I grab the olde Briwax. Good Luck, let us know how that maple looks so dark
before you have a finish on it?
-- WoodyG
RussellAP
#2 posted 12-04-2012 01:17 AM
It just came off the lathe that way Woody. I was thinking a spray can of some lacquer or just use some Charles Neil on it and buff it out. I need to seal up that end grain with something that wont soak in.
117063 posts in 3544 days
#3 posted 12-04-2012 01:31 AM
Any finish you put on it will change the look,some more than others because your dealing with end grain.
RussellAP
#4 posted 12-04-2012 01:33 AM
Jim, that’s my point. I wonder if the spray cans of lacquer will seal without discoloration if I do lots of very light coats?
View NiteWalker's profile
NiteWalker
2736 posts in 2544 days
#5 posted 12-04-2012 03:40 AM
A water borne finish like crystalac super premium will not change the color.
View waho6o9's profile
waho6o9
8165 posts in 2544 days
#6 posted 12-04-2012 04:00 AM
Hopefully you’ll have some off fall pieces to practice on.
Sure does look nice Russell.
I’ve had good luck with wipe on poly.
RussellAP
#7 posted 12-04-2012 04:02 AM
You guys know what? This is Elm, not curly maple. I got both the same day and not being a tree expert, I thought I grabbed the maple. Sure did smell good while I was turning it though. Does elm smell good?
View Wdwerker's profile
Wdwerker
333 posts in 2200 days
#8 posted 12-04-2012 04:06 AM
Water based finishes will be your best choice.
-- Fine Custom Woodwork since 1978
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3125 days
#9 posted 12-04-2012 04:16 AM
Spray shellac, lacquer, or water-borne film finish is your best bet. Glue sizing is another possibility.
Regardless, sand to about 100 zillion grit to help block saturation.
-- jay, www.allaboutastro.com
