| Forum topic by rustynails | posted 170 days ago | 507 views | 1 time favorited | 8 replies | ![]() |
170 days ago |
Currently I am working on getting my duct collector system completed as some of you my know by some of my most recent posts. Thanks Richard |
8 replies so far
#1 posted 170 days ago |
Avoid the screw-type clamps. Just a PITA Get these 4in squeeze type clamps instead, from woodcraft:
-- HorizontalMike -- "Woodpeckers understand..." |
#2 posted 170 days ago |
+1 on those spring clamps for temporary connections. i’ve found these work quite well for more permanent connections: http://www.rockler.com/product.cfm?page=16963&site=ROCKLER -- there's a solution to every problem.......you just have to be willing to find it. |
#3 posted 170 days ago |
This is where I get everything for my dust collection. cheapest hoses and everything is compiled into one site. http://www.ptreeusa.com/dust_list.htm Here are the hose clams i use and they are pretty good: http://www.ptreeusa.com/dusthoseclamps.htm |
#4 posted 170 days ago |
I use the cheap rockler screw type clamps for my permanant conections, and they seem to hold fast. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#5 posted 169 days ago |
I take a standard screw type 4” clamp and cut it a couple inches or so back from the screw. I then rivet the 2 parts of a draw latch to the opposing ends, so I can quickly unfasten and quickly re latch as needed. I still use the screw adjuster because not all 4” DC fittings are the same size. Can anybody tell me why that is, by the way? I’ve made several of these because I have to move hoses pretty often. Haven’t done so yet, but I’m going to try wiring some clamps on the ends of the hoses that I have to move most often, so they don’t slide off. I’ll tape over the holes where the wire goes through. |
#6 posted 169 days ago |
I move the single DC hose to all of my tools as I need them. I have worn out countless screw-type clamps and sure like having the squeeze clamps A LOT! The screw clamps also eventually wore holes in the end of the hose. -- HorizontalMike -- "Woodpeckers understand..." |
#7 posted 167 days ago |
+1 on the woodcraft——-I have exactly the same experiences as HorizonalMike…. |
#8 posted 167 days ago |
Thanks for all the input. Sounds like the squeeze spring type clamps are the way to go I will check around for the best price and get some ordered. Thanks Richard |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1533 |
3550 |
15787 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
