need a bandsaw blade for resawing that wont go dull
Forum topic by Mike Gager posted 12-03-2012 01:33 PM 3876 views 0 times favorited 28 replies Add to Favorites Watch
View Mike Gager's profile
Mike Gager
665 posts in 3237 days
12-03-2012 01:33 PM
Topic tags/keywords: question bandsaw
recently bought an olson blade for my bandsaw, its a 1/2 inch 6 tpi hook style i know its not the best resaw blade but the only thing i could find locally
i played around with it and cut a beech 1×2 into 1/8 strips and it worked well. a couple days later i went to cut a piece of maple into 3/8” halves and the thing would barely cut through it, same thing with mahogany and poplar. could it be dull already after cutting the beech? is that normal for these cheap blades?
what is a good lower cost blade that will last a while doing mild resawing? i mostly will be cutting boards in half for box making and nothing wider then 6” as thats the limit of my band saw
28 replies so far
10283 posts in 3617 days
#1 posted 12-03-2012 01:48 PM
I recommend 3 tpi for resawing.
You can flip steel blades and install them upside down
on a band saw to grind the gullets with a Dremel-type
tool. Brings new life to dulling resaw blades.
View bondogaposis's profile (online now)
bondogaposis
4690 posts in 2321 days
#2 posted 12-03-2012 01:49 PM
First off, all blades will dull with use, even carbide. You need to get a better re-saw blade, 6tpi is too many teeth for re-sawing. If your blade dulled w/ one use, it is probably because it overheated. Get a 3 TPI premium blade and you will be a lot happier.
-- Bondo Gaposis
View HorizontalMike's profile
HorizontalMike
7749 posts in 2883 days
#3 posted 12-03-2012 02:55 PM
Let me be the 3rd to say that you need a 3-TPI blade. With 3-TPI resawing, you won’t be fighting buildup in the gullets and the blade will run cooler and cut quicker.
Mike Gager
#4 posted 12-03-2012 03:01 PM
yeah i figured 6 tpi wouldnt be ideal but its all i could find locally. do you guys have a recommendation on brand of blade i should get? ive found a few online for around $20-30 so i would like to stay around that or less if at all possible as im on a pretty low budget
#5 posted 12-03-2012 06:09 PM
The ones from Lee Valley are a good value. Cheaper than
Timberwolf blades and about the same, imo.
http://www.leevalley.com/us/wood/page.aspx?p=30276&cat=1,41036,41037
You didn’t mention what size saw you have, but there
are a lot of blades on ebay at less than you’d pay from
a dealer.
Laguna has a line of Swedish blades they are selling on
ebay too:
http://www.ebay.com/itm/Laguna-Tools-ProForce-Bandsaw-Blade-1-2-x-3-tpi-x-93-1-2-Band-saw-Light-Resaw-/390436996136?pt=LH_DefaultDomain_0&hash=item5ae7dbc428
HorizontalMike
#6 posted 12-03-2012 06:17 PM
Loren has the ideas/suggestions. I personally use the Timberwolf 3/4in 3TPI on my BS and am pleased with the results.
FWIW, sometimes “cheaper” isn’t really any “cheaper” if they do not last/cut for the same length of time or amount of wood.
View Surfside's profile
Surfside
3389 posts in 2143 days
#7 posted 12-03-2012 07:35 PM
I recommend you to use Haltbar blades. Try to check www.sawblade.com . They have good quality blades.
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View MonteCristo's profile
MonteCristo
2099 posts in 2158 days
#8 posted 12-04-2012 04:35 AM
Low cost blades are not going to cut well for long – if you want a good blade it’s gonna cost, it’s just that simple.
View waho6o9's profile
waho6o9
8168 posts in 2546 days
#9 posted 12-04-2012 04:39 AM
+1 for Horizontal Mike and MonteCristo.
I’m glad you didn’t get to messed up when you went vertical Mike. Take care.
View pintodeluxe's profile
pintodeluxe
5626 posts in 2783 days
#10 posted 12-04-2012 05:50 AM
No, that’s not normal. I use Olsen All-Pro 3 tpi hook blades for resawing. They last me about a year. At that point they will still cut curves etc, but are too dull to accurately resaw. I use my bandsaw for each and every project, and turn out quite a few projects.
The blades are $20, and while not carbide I think the All-Pro is a step up in quality from the basic Olsen blades.
They will resaw stock to within 1/32”, which really helps make the most of my lumber supply.
View RogerM's profile
RogerM
792 posts in 2368 days
#11 posted 12-04-2012 02:57 PM
Hello Kansas (from a former Kansas State graduate). As noted above, 6 TPI blades are way too many teeth for resawing. Get down into the 2 and 3 TPI blades for much better resawing capabilities. Timberwolf now offers a 2/3 TPI blade that works very well for resawing The alternating tooth spacing does a better job as it reduces the harmonics and eliminates sawdust waste faster. The Wood Slicer blade offered by Highland Hardware in Atlanta is also an excellent resaw blade but does not stay sharp as long. Like most things you get what you pay for. Cheap box store blades will not stay sharp long.
-- Roger M, Aiken, SC
Mike Gager
#12 posted 12-04-2012 04:28 PM
roger i saw the timberwolf 2/3 blade you mention on woodcraft.com but it only shows as 3/4” i have a ridgid 14” saw (93.5” blade) i think 3/4 might be to much for it
they also have the olsen all-pro in 5/8” which i think would probably be pushing it.
Mike Gager
#13 posted 12-18-2012 04:26 PM
update: went with a laguna blade 3 tpi and it made a huge difference in the cut. saw is still pretty underpowered for thick resaws but a slow feed rate turns out a nice cut finish
Surfside
#14 posted 12-18-2012 05:08 PM
Cool Mike! Goodluck on that!
www.bandsawblog.com
View Woodbum's profile
Woodbum
808 posts in 3035 days
#15 posted 12-21-2012 02:27 PM
Mike: I use the Woodslicer from Highlland Woodworking exclusively for resawing. It is not cheap, but it works very well. It is a 1/2” 3 TPI with deep gullets. Also, whichever blade you buy, dedicate it for resawing. Once you make curved cuts with a resaw blade, forget it for resawing.
-- "Now I'm just another old guy wearing funny clothes"
showing 1 through 15 of 28 replies
