Question about plans
Forum topic by briandickens posted 461 days ago 299 views 0 times favorited 10 replies Add to Favorites Watch
View briandickens's profile
briandickens
17 posts in 486 days
461 days ago
Topic tags/keywords: adirondack chair plans taunton fine woodworking question resource
Having just bought my table saw, I’m trying to think of things to do with it that will impress the wife so I can start spending some money on this hobby. I’ve decided a good, easy, cheap(iish) start would be to build a few adirondack chairs for the deck. I’ve seen some plans online and they look fairly easy, but challenging for a newbie like me. I saw a link to plans for the chair as discussed in a Fine Woodworking article, but the plans seemed to be fairly expensive. Now, I don’t mind paying for quality things, I just need to know if they’re actually quality. So, has anyone bought the plans from FWW? Are they better than other plans? Alternatively, anyone know a nice looking Adirondack plan?
Here ’s the one I was looking at, btw.
Thanks as usual for the help.
View trifern's profile
trifern
7894 posts in 663 days
461 days ago
Hey Brian, here is a link for free plans from Jet.
View AndyDuframe's profile
AndyDuframe
7 posts in 486 days
461 days ago
Wow…I think $20 is kind of pricey for a set of adirondack chair plans. The going rate for downloadable plans on the Web is usually around $7 – $10.
The biggest difference I’ve seen in plans from one place to the other is the complexity of the design itself. I think some wood designers go a little over the top in making the joinery way more complicated than it really needs to be. And that extra complexity usually translates into a lot of extra tools and equipment in the shop to get it built. Unfortunately most plan descriptions don’t tell you this stuff one way or the other. So it’s kind of gamble when buying plans.
I’ve found some really simple designs for outdoor furniture just by browsing around a home center and looking realy close at how those (imported) chairs are put together. Maybe even sneak in a camera and take a few shots.
-- http://www.ezwoodshop.com
View sIKE's profile
sIKE
1094 posts in 650 days
461 days ago
Norm has a several plans for different type of Adirondack chairs that you can get also, the later ones have full size templates which you will appreciate and you can buy a DVD of the episode also. You can find Norms stuff at http://www.NewYankee.com
Good luck these chairs they are a good gateway project for woodworkers just starting out.
briandickens
461 days ago
Thanks everyone. I like the look of the ones from Jet, and the price is right. I may try doing this before building a workbench.
View CoolDavion's profile
CoolDavion
215 posts in 721 days
461 days ago
There was a bench in American Woodworker a couple months back.
You could check your local library for back issues of magazines or books.
-- don't sweat the petty things and don't pet the sweaty things
View DaveR's profile
DaveR
1527 posts in 617 days
461 days ago
I drew up plans for an Adirondack chair some time ago. Actually I have yet to dimension it but I probably could do it for you if you want. Or I could just e-mail you the SketchUp file and you can work from that.
-- Until you spread your wings, you'll have no idea how far you can walk.
briandickens
461 days ago
if you don’t mind emailing the file, that would be great. email should be in my profile.
View jtreynoldsJTR100's profile
jtreynoldsJTR100
9 posts in 473 days
460 days ago
You happened to hit on a subject dear to my heart – Adirondack chairs
Here a link to some free plans from Popular Mechanics
http://www.popularmechanics.com/home_journal/workshop/2919751.html
I like these chairs because they have curved back and seats – I find them more comfortable than flat.
Since these chairs are probably going to be outside, prepare them for the weather. Some of the things you do during construction that don’t take much extra time can add a lot to their longevity.
Coat all the pieces with either primer or stain/sealer (depending on whether you final finish is stain or paint) before you assemble.
Use exterior glue (I’d use Gorilla glue or the equivalent) to add strength but mainly to reduce moisture from wicking into the joints.
You can just use deck screws to put it together, but it’s best if you countersink them and plug the holes with solid wood plugs (a bit to cut the plugs isn’t too expensive). That keeps water from tracking along the screws and eventually weakening the joint.
Use carriage bolts for the main structural connections, eg legs to seat.
Leave a gap between the slats on the back at the bottom – at least 1/4”. If you keep them snug, they’ll trap debris and moisture.
Hope this helps.
Have fun. This is a great project. I’m sure your wife will be impressed.
-- Jake http:/www.adirondackchairscentral.com
View Jim Crockett's profile
Jim Crockett
325 posts in 629 days
458 days ago
Here is a set of plans for “Jake’s Chair”, a really nice Adirondack chair – and they are free.
The website is located at http://www.internetwoodworking.com/w5/chair.html
Jake's Chair
View Slacker's profile
Slacker
177 posts in 597 days
458 days ago
I was in Puerto Rico recently and the beach house where I stayed had a store bought adirondack chair made in mahogany. The chair was very nice, that is, until you sat down. The down angle was not right, and the chair was not deep enough. It was highly uncomfortable.
About the only good thing about it was those wide arms to properly hold your drink…
-- There are three kinds of people... those who can count, and those who can't
