Need help hanging a shelf for a heater in the shop/garage.
Forum topic by Vodo posted 12-03-2012 02:30 AM 1672 views 0 times favorited 14 replies Add to Favorites Watch
View Vodo's profile
Vodo
18 posts in 1967 days
12-03-2012 02:30 AM
Topic tags/keywords: shop shelf heater fasteners design
Greetings all.
I want to hang a heater on a wall in my shop/garage for the winter.
The heater is 12×12x16.
The wall looks like so:
There are 2 studs in between the left cabinet and the breaker box. I was thinking of making the shelf long enough to put the heater on, as well as maybe some other things. I would think it would need to hold at least 50 pounds.
The “shelf” would need to stick out about 17 inches from the wall.
I do have supporting “rails” like this in abundance:
I also have a ton of MDF, screws, etc..
I was hoping to do this without having to go out and buy steel shelf brackets.
I had thought of something looking like one of these:
I’m looking for thoughts and suggestions about how to fasten it to the wall to be sturdy, and to prevent the shelf from “sagging” forward and thus spilling everything off of it.
What do you think?
-- AKA vodo. I belong in a blue state.
14 replies so far
TopamaxSurvivor
18247 posts in 3641 days
#1 posted 12-03-2012 06:09 AM
Heaters like that usually have minimum clearances for air flow and fire prevention.
View Richard's profile
Richard
400 posts in 2657 days
#2 posted 12-03-2012 12:42 PM
I would be leery of putting a heater on a shelf, period. Too much opportunity for impeded air flow.
And, since heat rises, it seems like it would be more effective if it was placed on the floor.
-- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain
Smitty_Cabinetshop
15280 posts in 2584 days
#3 posted 12-03-2012 01:08 PM
Looks like hanging might be an option. And put some sheet steel above it to dissipate heat…
View dhazelton's profile
dhazelton
2755 posts in 2262 days
#4 posted 12-03-2012 02:02 PM
ASSUMING you can put that heater on a shelf – your support legs are undersized on your sketch. They should come out probably as far as the shelf is deep. I’d build a 2×3 or 2×4 frame that is a bit wider than your studs, screw the frame to the wall, then add some legs at a 45 degree angle, also screwed into the studs. Put your shelf material on top of the whole affair. Or go buy some steel shelf standards and brackets and make sure they go into the studs. Stay away from putting a screw into the wall on the same height as the wall outlet in case the wire runs to another box through that area.
View Toolz's profile
Toolz
1004 posts in 3708 days
#5 posted 12-03-2012 03:57 PM
I have a 220V version of that same heater. I placed mine on fire bricks on top of a 3 drawer metal file cabinet. The bricks are just to raise the heater a little so I could place a stronger fan in front of the heater to get the heated air projecting further out into the shop. I was limited for placement due to cord length and 220 outlet location. I have a 150K kerosene heater as my main heat source and use this little heater to help maintain temp after the kerosene heater’s thermostat kick it off when it reaches the desired temp. Placing it on the file cabnet I already had for non flammable storage worked best for me.
-- Larry "Work like a Captain but Play like a Pirate!"
View madts's profile
madts
1855 posts in 2305 days
#6 posted 12-03-2012 04:18 PM
You could hang the outboard end with wire rope from the ceiling
-- Thor and Odin are still the greatest of Gods.
View Vodo's profile
Vodo
#7 posted 12-04-2012 02:02 AM
Thanks for the advice so far guys. I think I will entertain the option of hanging it or putting it on some stand. I still plan on putting some functional shelves there anyway though.
Thanks again!
dhazelton
#8 posted 12-05-2012 03:02 PM
If you still pursue the shelf idea just get a sheet of the cement backer board (the stuff that’s a base for tile in the shower) and cut that into a couple of pieces to use as a fireproof barrier.
View JoeinGa's profile
JoeinGa
7735 posts in 1972 days
#9 posted 12-05-2012 03:18 PM
I bought this same heater last year. Cant tell which model yours is but mine’s 220volt. Anyway… At first I tried to hang it from the rafters with 2 short pieces of chain. Problem is, my workshop is open to the top (i.e. no ceiling, just the rafters), so the heat went mostly UP. My ceiling fans helped some, but I felt that it was taking too much to heat the area I wanted to be warm enough to work in.
So I welded together a simple open-box shaped stand and put some small casters on it. I made a 20’ long extension cord that is plenty heavy enough to carry the load and now I can roll it around my shop to get more (or less) heat where I’m working.
You could just as easily use wood for the stand.
In the winter I covered it with a trashbag and stored it on a high shelf out of the way.
JoeinGa
#10 posted 12-06-2012 10:42 PM
Here’s a pic of the stand I made for mine.
View RussellAP's profile
RussellAP
3103 posts in 2252 days
#11 posted 12-06-2012 11:00 PM
I would leave that on the floor out in the path and move it when I’m working. maybe put it on something non conductive and not flammable. That way you stay in contact frequently and can see if it needs blowing out. I opt’d for the radiator type heater and a small fan on the other end of the room to circulate air.
View Jim Finn's profile
Jim Finn
2647 posts in 2887 days
#12 posted 12-06-2012 11:31 PM
I have installed a lot of heaters similar to yours, only larger, and we hung them from the overhead using pipe or all-thread rod.
-- Website is https://craftingcouple.com/
View Vodo's profile
Vodo
#13 posted 12-07-2012 01:22 AM
That is a cool stand.
The more I think about it, the more it’s going on a stand.
View HorizontalMike's profile
HorizontalMike
7749 posts in 2879 days
#14 posted 12-07-2012 01:24 AM
Joe,
That looks like the right answer for you. That way you could even have it directed in your direction when it is really cold. Nice job.
