Table Saw Blade Moves While Cutting
Forum topic by SteveD787 posted 172 days ago 507 views 0 times favorited 12 replies Add to Favorites Watch
View SteveD787's profile
SteveD787
3 posts in 179 days
172 days ago
Topic tags/keywords: table saw problem tablesaw
I have a portable Ryobi table saw and I keep getting cuts that are not 90 degrees. Today I noticed that as I was making a cut the blade was actually being forced/moved to the left by the wood. The rip fence was square. I checked the blade and it is tight, could it be a worn out or just too dirty? Is it just a low quality table saw that I will have to live with until I up grade?
Steve
-- Steve
12 replies so far
View Loren's profile
4893 posts in 1818 days
#1 posted 172 days ago
blade tilt lock handle is tight?
87255 posts in 1748 days
#2 posted 172 days ago
Do you have a thin kerf blade ? If so it could just be blade flex.
View Ted's profile
Ted
1400 posts in 382 days
#3 posted 172 days ago
It’s probably the fence causing the problem. It may be bowed or not parallel with the blade or both. Slide the fence all the way to just touching the blade, to see if it touches the front or back of the blade first. Hold the slider (the “T” part) tight to the rail as you do this. It should touch both front and back of the blade at the same time. Of course, don’t do this with the saw running, but I’m assuming you know that.
To see of the fence is bowed, hold a known straight edge against it. A level or steel yardstick will do. If it’s bowed, you can fasten a straight piece of 3/4” oak or similar wood to it, by drilling through and screwing from the opposite side of the fence.
I also have a Ryobi table saw and it’s not a bad saw for the price… just takes a little tweeking to make it work properly. Have you tried a full 45 deg. bevel cut yet? I had to chop out a piece from the side of my saw to get it to tip all the way, because it was hitting on the inside at about 44.5 deg. :)
-- I'll grow up when ketchup bottle farts stop being funny.
View NiteWalker's profile
NiteWalker
1477 posts in 747 days
#4 posted 172 days ago
It’s a low quality tablesaw.
View REO's profile
REO
286 posts in 245 days
#5 posted 169 days ago
My bet would be a dull blade
View crank49's profile
crank49
2289 posts in 1141 days
#6 posted 169 days ago
Get you a decent new combo blade on that saw and it will probably surprise you how much better the saw will work. Then clean the old blade and keep it for a spare or a beater blade for when you are cutting questionable material.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View syenefarmer's profile
syenefarmer
332 posts in 1251 days
#7 posted 169 days ago
Bad arbor bearings??
View dhazelton's profile
dhazelton
832 posts in 467 days
#8 posted 169 days ago
That will happen with an expensive saw as well if not used correctly. Your blade may be too thin for the stock you are cutting, have too many teeth or be dull. Also make sure the guides are down close to the workpiece, and not way up exposing too much blade. I had a little Black and Decker 3 wheel unit that was all plastic, and for small work – nothing over one by thickness – it was fine. I made a lot of Adirondack chairs and birdhouses and such with it. Good luck.
View ajosephg's profile
ajosephg
1721 posts in 1732 days
#9 posted 169 days ago
hazelton – he’s talking about a table saw, not a band saw.
-- Joe
View rockindavan's profile
rockindavan
254 posts in 807 days
#10 posted 169 days ago
I occasionally have the same issue with my old dewalt saw with the rack and pinon fence. It sometimes skips a gear the fence is not parallel with the blade. As the board goes through it forces out the blade and bends it. I would put my money on this being your problem.
dhazelton
#11 posted 168 days ago
D’oh! Thin cheap blade or too much blade exposed still applies…
View lumberjoe's profile
lumberjoe
2401 posts in 419 days
#12 posted 168 days ago
My money is on Loren. I had a Ryobi RTS10. The tilt lock DOES NOT stay locked. I had to check it before and after every cut. Pull the lever off and tighten it with a hex key. It’s a pain if you ever actually want to tilt the blade, but it will stop you from pushing it over.
-- http://www.etsy.com/shop/KandJWoodCrafts
