Finish for a trivet
Forum topic by lumberjoe posted 12-03-2012 12:58 AM 1083 views 0 times favorited 8 replies Add to Favorites Watch
View lumberjoe's profile
lumberjoe
2894 posts in 2121 days
12-03-2012 12:58 AM
I’m making my mom a trivet for Christmas this year. It’s just about done and it’s one of the only projects I have ever done that came out as good as I had hoped it would have. My only issue now is finish. Because of the design, it really has to be sprayed. I also don’t have much room to rub out the finish much, but I could get in there gently with some steel wool or a scotchbrite pad.
What will hold up the best? I have sprayed many coats of VERY thin ploy with success and extremely minimal rubbing out after. Will that stand up to heat?
8 replies so far
View ShaneA's profile
ShaneA
6879 posts in 2471 days
#1 posted 12-03-2012 01:03 AM
I just used pure tung oil on mine last year. No clear coat of any kind. I bet mineral oil would be fine too.
lumberjoe
#2 posted 12-03-2012 01:08 AM
I was thinking of mineral oil, but since this doesn’t have to be food safe like a cutting board, I want it to look nice. Mineral oil looks ok, but it will wear down over time.
View Brandon's profile
Brandon
4152 posts in 2824 days
#3 posted 12-03-2012 01:21 AM
I think I used tung oil on mine too. Wipes on pretty easily.
-- "hold fast to that which is good"
View jap's profile
jap
1251 posts in 1927 days
#4 posted 12-03-2012 02:01 AM
i’ve used linseed oil before, worked fine
-- Joel
View MisterBill's profile
MisterBill
411 posts in 2125 days
#5 posted 12-03-2012 12:40 PM
I have been happy with the finish that I got when I used Watco Danish Oil. Others have recommended Deft Lacquer in a rattle can.
lumberjoe
#6 posted 12-03-2012 01:01 PM
I may try the oil route. If I do it will be Danish oil (because that is what I have). I’ve never used rattle can lacquer, but I would consider it. Does it require as much rubbing out as brushing lacquer?
View kepy's profile
kepy
293 posts in 2146 days
#7 posted 12-03-2012 01:47 PM
I have used mineral oil with good results. After letting it dry, then buffed with a brown paper bag. It can always be refreshed if it fades over time. Most of the oils should work although I don’t think lacquer would take the heat. Most of the ones I have given have wound up on the wall rather than getting used.
-- Kepy
View Mike Gager's profile
Mike Gager
665 posts in 3140 days
#8 posted 12-03-2012 03:06 PM
i used watco danish oil on the one i made, its held up fine so far
