What's your grain filler of choice?
Forum topic by Purrmaster posted 12-02-2012 11:58 PM 1476 views 0 times favorited 11 replies Add to Favorites Watch
View Purrmaster's profile
Purrmaster
915 posts in 2092 days
12-02-2012 11:58 PM
I’m making a project out of ash. Which, like oak, has very open pores. I probably won’t fill the grain on this project but I’d like to try it some time.
What do you like best for filling grain? I’ve collected some sanding dust in case mixing my own pore filler would work. But I’m open to all methods.
Opinions?
11 replies so far
View Clint Searl's profile
Clint Searl
1533 posts in 2361 days
#1 posted 12-03-2012 02:12 AM
Filler destroys the character of any wood. Plain sawn white ash has beautiful grain that doesn’t need anything clouding it.
View Fuzzy's profile
Fuzzy
298 posts in 3988 days
#2 posted 12-03-2012 02:19 AM
Drywall compound … ... ...
You can apply it as is, and stain/dye the entire piece … or … color the piece, THEN color the filler for effect prior to application. This way, you can enhance or minimize the grain with different color combinations. THIS is where finishing departs from stark mechanics, and becomes a bit of an art. You can make or break a piece based on it’s physical appearance, and color has much to do with it’s success/failure.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
Purrmaster
#3 posted 12-03-2012 02:39 AM
If I colored the wood before coloring the filler I assume I would put on my stain and then slap on the drywall compound?
Does anyone use solvent based pore fillers? I’m having a devil of a time finding oil based fillers and dyes. They all seem to be waterbase.
Purrmaster
#4 posted 12-03-2012 04:36 AM
The reason to fill the pores would be to get a smooth, mirror like surface. I am concerned about how it would affect the appearance.
View CharlesNeil's profile
CharlesNeil
2399 posts in 3870 days
#5 posted 12-03-2012 02:22 PM
Aqua coat , ( water base) it dries clear and clean ,for oil base check Mohawk Finishes Pore O pac
View Earlextech's profile
Earlextech
1161 posts in 2690 days
#6 posted 12-03-2012 03:00 PM
Aquacoat Grain Filler – along with all of their products – is excellent.
CharlesNeil
#7 posted 12-03-2012 03:01 PM
I agree Earlex .. good stuff
Purrmaster
#8 posted 12-04-2012 05:56 AM
I’ll take a look at Aquacoat. What about Crystallac? There’s only one review on here.
View BigYin's profile
BigYin
416 posts in 2416 days
#9 posted 12-04-2012 06:57 AM
Liming (lime-ing) if the effect suits you
http://www.bozzle.com/id_limingwood.html
-- ... Never Apologise For Being Right ...
404 - Not Found
2544 posts in 2969 days
#10 posted 12-04-2012 12:11 PM
I’ve had good results just using lacquer. Pour some on the piece, squeegee it into the pores with a straight edge (I have loads of old planer knives lying around and use those), wait till it’s dry, sand it level, start spraying. Job done.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3158 days
#11 posted 12-04-2012 02:22 PM
I’m kinda with Renners on that. I like to use a little oil/varnish mixture and sand up a little bit of slurry, rubbing it into the pores. Let it harden a bit, sand back, and then spray a sealer coat. You may have to do it twice, but that’s true of most pore filling operations.
I’ve also done the French polish method by adding some pumice (for light woods) into shellac with a little oil. You can use rottenstone for darker woods, like walnut.
-- jay, www.allaboutastro.com
