Steel wool? ScotchBrite? Which one and Why?
Forum topic by Lee Barker posted 12-02-2012 08:47 PM 14627 views 0 times favorited 19 replies Add to Favorites Watch
View Lee Barker's profile
Lee Barker
2170 posts in 2814 days
12-02-2012 08:47 PM
Do you have both in the drawer?
If not, which do you prefer and why?
If so, which do you use where and why?
Kindly,
19 replies so far
View Deycart's profile
Deycart
444 posts in 2221 days
#1 posted 12-02-2012 09:13 PM
I have used both and I use steel wool for oil finishes and scotchbrite for water based finishes. Steel wool is way cheaper so I tend to use oil finishes mostly. Plus it is way easier to find and find it in different grades.
View Terry Ferguson's profile
Terry Ferguson
203 posts in 2631 days
#2 posted 12-02-2012 09:29 PM
I agree with the previous post. I mostly use scotch brite or similar and less expensive sanding/abrasive pads from the big box stores. 0000 steel wool is kept around for metal parts and tools – steel and brass, although I’m not fond of little particles that come off in use. I don’t apply danish oil finishes with either one, but prefer to use rags and wet or dry sandpaper. I have used both wool and pads, along with various products, to remove rust.
Lee: I’m wondering what your experience is?
-- Terry Ferguson, Bend Oregon
View jumbojack's profile
jumbojack
1674 posts in 2588 days
#3 posted 12-02-2012 09:29 PM
I hate steel wool. the only thing I find it useful for is plugging up holes so vermin do not get in the house.
jumbojack
#4 posted 12-02-2012 09:30 PM
I hate steel wool. the only thing I find it useful for is plugging up holes so vermin do not get in the house. Give me 600 grit wet/dry any day.
View waho6o9's profile
waho6o9
8162 posts in 2541 days
#5 posted 12-02-2012 09:36 PM
Bronze wool doesn’t rust.
Steel wool is for metal IMHO.
Not into Scotchbrite. Sand paper rules!
View greg48's profile
greg48
600 posts in 2721 days
#6 posted 12-02-2012 10:14 PM
Generally have 1-2 grades of steel wool around. Mostly to clean saw tops, ways (shop smith), etc. and apply wax thereto. Never tried ScotchBrite on anything but the kitchen sink.
-- Greg, No. Cal. - "Gaudete in Domino Semper"
View vipond33's profile
vipond33
1405 posts in 2461 days
#7 posted 12-02-2012 11:31 PM
Steel wool, 0000 grade (made in USA only) can’t be beat for rubdowns as it will flex down into the pores on open grain wood and is great generally as you can touch up and instantly see your progress. It conforms easily to curves and works great on small bevels without cutting through like sandpaper. I use it with wiping varnish, oils, wax and also dry for a “furniture” finish (pre-scratching). Having said all that I simply hate the problem of breakdown and bits of steel. Still, I’d never give it up, you’ll have to pry it out of my cold dead hands.
-- gene@toronto.ontario.canada : dovetail free since '53, critiques always welcome.
View Moron's profile
Moron
5032 posts in 3857 days
#8 posted 12-02-2012 11:34 PM
I stopped using steel wool after noticing micro small bits of it, left under or in the finish, then oxidizing and leaving small greenish dots. Now I use it to apply a wax coat only
Started using a product that looks like scotch brite but it isnt. Available at speciatly abrasive and finish suppliers in rolls approx., 6 “ x 50 ft. Comes in different grits and is perfect for sanding between coats of lacquer where crisp edges from coping are, cant sand through the stain.
Cheers
View bobasaurus's profile
bobasaurus
3405 posts in 3148 days
#9 posted 12-02-2012 11:35 PM
000 or 0000 steel wool is great for in-between finishing stages, but the steel dust drives me nuts and I always end up with some in my finish. The synthetic steel wools (scotchbrite-like pads) work okay, but they don’t scuff up surfaces to the same degree as real steel wool and so subsequent coats don’t really build as quickly. I have yet to settle on one or the other… seems like I alternate every time I finish something.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
Deycart
#10 posted 12-02-2012 11:42 PM
Moron, Could you post a link to your supplier?
View Ted's profile
Ted
2838 posts in 2175 days
#11 posted 12-02-2012 11:50 PM
I keep both on hand, of all different grades, for way to many uses to list here. As for scuffing between finishes, I prefer sandpaper, sanding sponge or steel wool. Scotch bright starts off too scratchy and quickly turns to not scratchy enough.
-- You can collect dust or you can make dust. I choose to make it.
117061 posts in 3541 days
#12 posted 12-02-2012 11:51 PM
I have never had a use for steel wool ,sand paper does the job for me.
View longgone's profile
longgone
5688 posts in 3272 days
#13 posted 12-03-2012 01:05 AM
I use steel wool and solve the fne particle problem by putting a couple of magnets inside a piece of fine cloth and lightly rubbing over the work. works like a charm.
Terry Ferguson
#14 posted 12-03-2012 01:33 AM
I’m just looking through the Lee Valley catalog (page 209) and I see a product that I’m unfamiliar with. It’s called “Siawool” – nylon fiber impregnated with silicone carbide abrasive particles, so no steel fragments. Right next to that are Norton 3X contour pads – aluminum oxide on high density foam. Anyone tried these?
Moron
#15 posted 12-03-2012 01:47 AM
@ DayCart
Cant help you. I gave up woodworking several years ago in favour of guiding people through it
Google it, U Tube it
Abrasive suppliers/Specialty finishing supplies
Merry Christmas
