holding a round knob??
« back to Coffee Lounge forum
Forum topic by Belg1960 posted 12-02-2012 05:01 PM 1394 views 0 times favorited 5 replies Add to Favorites Watch
View Belg1960's profile
Belg1960
1062 posts in 3027 days
12-02-2012 05:01 PM
Topic tags/keywords: question
Guys, I have to drill some wooden knobs out that have a 1/8 hole out to make it 5/8 how would you hold them so I can use the drillpress and not damage the exterior of the knob? This is almost the exact knob I’m working with. Thanks
-- ***Pat*** Rookie woodworker looking for an education!!!
5 replies so far
View Gshepherd's profile
Gshepherd
1727 posts in 2163 days
#1 posted 12-02-2012 05:05 PM
I wrap a small towel around them and stick them in a wooden vise, use the hand drill with a stop on it…. But since I have a lathe I would put them in the NOVA Soft Jaws and do it that way…....
-- What we do in life will Echo through Eternity........
TopamaxSurvivor
18241 posts in 3638 days
#2 posted 12-02-2012 06:08 PM
I’d do it the same way, but add a set of V blocks to hold it in the vise. i would probably use a battery drill with a very light touch on a slow speed.
View bandit571's profile
bandit571
19705 posts in 2645 days
#3 posted 12-02-2012 06:15 PM
Shop towel, hold with a pair of visegrips, clamp in place on the drill press.
Shop towel, hold with a wood “handscrew” type clamp, clamp to the table with a second one.
Vise jaws of wood, or just some cloth. Clamp knob in vise with the center point of the hole 5/16” above the top of the vise’s jaws. Use the vise’s jaws as a steady rest for the handdrilling. Tape as a depth stop wrapped around the bit.
Might be a few more ways out there….
Belg1960
#4 posted 12-02-2012 07:13 PM
Well after looking around a little while here’s what I came up with. I took a piece of 2×4 and drilled a shallow recess for the knob to sit in, then a square of 1/2” plywood with a hole slightly larger then the base and screwed the plywood to the 2×4 sandwiching the knob in the middle. Used my metal vise to hold the 2×4 leveled with a a bubble level in the center. Then used my drill press to make the hole. Worked great!!
View bluekingfisher's profile
bluekingfisher
1250 posts in 2941 days
#5 posted 12-03-2012 11:02 AM
Great work Pat, you shouls patent that idea.
Glad it worked out for you.
-- No one plans to fail, they just, just fail to plan
