Rust hunting, found a mystery plane
« back to Hand Tools forum
Forum topic by bandit571 posted 12-02-2012 02:23 AM 1503 views 0 times favorited 6 replies Add to Favorites Watch
View bandit571's profile
bandit571
21990 posts in 2920 days
12-02-2012 02:23 AM
Topic tags/keywords: resource plane refurbishing
Well, I did fine three such planes. Only bought two. One was a PARPLUS #5 that will be a source of parts. Yeah, I know, pressed steel frog again. Handles were is GREAT shape though.
The other of these two planes? Well, here is a little looksee..
No iron, chipbreaker, or levercap. Kind of a short base #4. Other side of the frog looked vaguely firmiliar, though
Do I see a Millers Falls detail, or two? Yoke for the adjuster is a two-piece steel thingy. A lot of the chrome plating is flaking off. It has a 7A stamped in the frog, along with what LOOKS like a 406.
Base has a little different idea about the tall front knob..
There are ridges down inside that ring? Another look around?
The tote has a stamp in it’s side “W.H. KIEFABER CO.” Bolts are two piece. Heads are plated, not sure what is under the plating.
As far as the PARPLUS #5 parts plane? That adjuster wheel is one of the smallest I’ve ever seen, less than 3/4’ in diameter. If that. All of it’s parts ARe there, darn it all. As for the one still at that store? A little #4 sized plane by WORTH, and at $20, I will PASS! These two cost a whole $12 total. May go back after next payday, there is a LOT of other hand toys, er, tools sitting there.
View RussellAP's profile
RussellAP
3104 posts in 2524 days
#1 posted 12-02-2012 02:46 AM
No idea, but a guy once told me that those painted frog planes are junk. I haven’t bought a colored frog since.
View shampeon's profile
shampeon
1894 posts in 2421 days
#2 posted 12-02-2012 06:20 AM
The U shaped lateral adjuster and 406 on the frog make it seem like a Sargent-made plane, not a Millers Falls.
View racerglen's profile
racerglen
3112 posts in 3018 days
#3 posted 12-02-2012 10:32 AM
Looks just like the Millers in pieces on my bench Bandit, but mine
has Millers Falls stamped lightly in the tote, same place yours has a name.
Mine is in peices waiting for my mechanic son to do his screw extraction thing on the
bolt for the tote
-- Glen, B.C. Canada
bandit571
#4 posted 12-02-2012 06:30 PM
Since this was for a Hardware Supply Company, would just a plain-jane lever cap do?
shampeon
#5 posted 12-02-2012 07:03 PM
Yeah. I doubt the lever cap had anything cast into it, for a small hardware company contract plane.
The adjustment wheel, tote & knob, and the knob casting ring in the body look like Millers Falls, actually.
bandit571
#6 posted 12-02-2012 08:31 PM
Progress so far:
Frog is coming along nicely..
sides and sole are getting there, need a new belt for the sander..
@ just over 13” long. PARPLUS #5. sides are looking a bit better…
sole will need a bit more work ( got to get a new belt..)
and a look up front. About an hour’s work so far…
