Mullions
Forum topic by depictureboy posted 101 days ago 143 views 0 times favorited 2 replies Add to Favorites
View depictureboy's profile
depictureboy
77 posts in 179 days
101 days ago
Topic tags/keywords: question mullions gluing
this is a continuation of this forum post
I did a search for mullions and didn’t come up with any hits. anyway, as you can see in that picture in the other thread, there is a mullion frame inside the panel. I have no issue making the mullion frame itself, its simply a few half lap joints….my question is how is the best way to attach them to the frame, I was thinking that simply butt gluing them similar to what you would do with a central stile would be OK. Since there is no profile along the inside of the frame there wouldn’t be any need to do any fancy copes or anything…I just need to just the mullions(i may not even put a profile on them), half lap them and glue them up….think that would work?
-- If you can't build it, code it. If you can't code it, build it. But always ALWAYS take a picture.
View DaveR's profile
DaveR
233 posts in 257 days
101 days ago
I’d cut recesses into the frame pieces to receive the mullions. And, if the mullions are to be flush or nearly so with the front of the frames, notch the ends of the mullions, too.
-- Quantum materiae materietur marmota monax si marmota monax materiam possit materiari?
View rhett's profile
rhett
45 posts in 204 days
101 days ago
You can cut a mdf square as a spacers for how far down on the stiles and how far in on the rails you would like the mullions. Use a router with a quide bushing and a bit the width of your desired mullion. Then simply pass your router into the frame sides. The depth of the cut will determine the thickness of the mullion. Put in your mullion stock and where it overlaps, cut your half lap joint. Changing the size of the mdf square will adjust where the mullions will land inside the frame.
-- http://www.efcabineture.com/ "Experience is what you get, when you don't get what you want"
Bookmark And Share This Page
