Molding Plane Design Questions
« back to Hand Tools forum
Forum topic by Ben posted 175 days ago 338 views 0 times favorited 3 replies Add to Favorites Watch
View Ben's profile
Ben
273 posts in 1885 days
175 days ago
Topic tags/keywords: question molding plane
Does anybody know why molding planes have a off center irons as opposed to a center blade? I would certainly think for construction sake it would be easier to use a centered iron and then taper both sides of the plane body as opposed to using an offcenter blade and tapering only one side of the plane. The reason I ask is because I want to make a set of molding planes, and am curious about the conventions of the design.
-- Do something nice for somebody
3 replies so far
View David Kirtley's profile
David Kirtley
1250 posts in 1170 days
#1 posted 175 days ago
Probably because of less waste cutting the iron from a flat bar but that is just a guess.
View Don W's profile
Don W
9973 posts in 740 days
#2 posted 175 days ago
And there are times you’ll want to plane right on an edge. It would be difficult with a centered iron.
View paratrooper34's profile
paratrooper34
699 posts in 1124 days
#3 posted 174 days ago
For work on the edge and for shavings ejection. The side escapement planes clog WAY less than the ones that have a center escapement.
-- Mike
