Now That's a CHAINSAW!
« back to Coffee Lounge forum
Forum topic by Tim Pursell posted 101 days ago 203 views 0 times favorited 6 replies Add to Favorites
View Tim Pursell's profile
Tim Pursell
222 posts in 319 days
101 days ago
http://www.youtube.com/watch?v=FvAI7-Qa2Io
-- http://www.grandprairiewoodworks.com
teenagewoodworker
2134 posts in 305 days
101 days ago
if you get kickback on that thing consider yourself a goner! very cool to see though!
View ChicoWoodnut's profile
ChicoWoodnut
748 posts in 352 days
101 days ago
Yikes! Just think of the torque and what would happen if the chain broke.
View LoneRider's profile
LoneRider
23 posts in 208 days
100 days ago
A longer video with the stats!
-- Tom - Canadian in N. Texas
View Dusty56's profile
Dusty56
1400 posts in 224 days
100 days ago
I don’t know what kind of scale they used to weigh that with ( 508 pounds ) these guys missed their calling if they can lift 254 pounds each plus control the torque of the engine…....or what type of stopwatch they timed it with ( 88 hundredths of a second ??? ) , but they’re both broken . Some ppl will believe anything.
-- Dusty56@comcast.net
View trifern's profile
trifern
4952 posts in 304 days
100 days ago
Might work better just mounted to the front bumper of the truck. Then you wouldn’t even have to get out. Just do a drive by.
LoneRider
100 days ago
Dusty,
I can believe it, at college I used to parallel park my ‘86 Escort between two tree by pulling in the front, and lifting the back of the car enough to drag the rear into the spot. I’ve also moved 200+ lbs tube TV sets by myself as well.
254 lbs is a lot, but in short durations, very doable. And once the blade is engaged in the wood, you will notice the saw drawn very tight to the log.
BTW, did I mention I also have a trick muscle in my back, every year or two it will just lock up for a couple of days. And I am due for shoulder surgery this fall :-)
cheers.
Bookmark And Share This Page
