Shelf design
Forum topic by jackthelab posted 173 days ago 634 views 0 times favorited 13 replies Add to Favorites Watch
View jackthelab's profile
jackthelab
235 posts in 863 days
173 days ago
Hi
I have a whole bunch of 1/2” OSB left over from a project and I was wondering if anyone out there has either a link to some designs or an idea of how to design decent hanging shelves from this material. Nothing fancy just functional. Any thoughts or ideas would be helpful – would really like to use up the stuff and not have to buy plywood. Note – these shelves would be used in the garage so the design or finish on them is not that important as long as they work.
-- Dave in Minnesota - If it ain't broke, improve it!
13 replies so far
View BentheViking's profile
BentheViking
1135 posts in 734 days
#1 posted 173 days ago
What do you mean by hanging shelves? If your worried about them sagging I’d suggest doing a piece across the front which will make it much stronger.
-- It's made of wood. Real sturdy.--Chubbs Peterson
View Bill White's profile
Bill White
2604 posts in 2130 days
#2 posted 173 days ago
Double it up. Make ‘em 1” thick and hope for the best. Even on 16” centers, 1/2” OSB will sag under heavier loads.
Bill
-- bill@magraphics.us
View Sandra's profile
Sandra
1291 posts in 245 days
#3 posted 173 days ago
You could make a frame with 2×4s and then use the USB for the shelving. I don’t have a link, but that’s where my head went. If you want them off the ground, you could use some of the lumber rack designs, which are essentially heavy brackets, and run the MDF across them….
My 2 cents worth.
S
-- No, I don't want to buy the pink hammer.
Sandra
#4 posted 173 days ago
I have a lumber rack in my projects. I used the design from wood whisperer. The long lag bolts to attach the uprights into the studs weren’t cheap though. You could make something like that, and then run the mdf across as shelves.
jackthelab
#5 posted 172 days ago
Thanks for the thoughts – Hanging shelves would basically mean off the floor.
View John's Woodshop's profile
John's Woodshop
346 posts in 2186 days
#6 posted 172 days ago
I wouldn’t use osb for the reason mentioned above, it sags too much!
John
-- John -- Racine, WI -- Woodworking..."It's not just a Hobby, it's an Adventure"
View renners's profile
renners
1892 posts in 1139 days
#7 posted 172 days ago
If you are determined to use the OSB up on this project, maybe you should make it with a face frame. You could put a solid back on it that will take fasteners for hanging – with a piece underneath the unit attached to the wall so it can sit on it and take the weight. Use a 2×1 lipping for the front of the shelves to stiffen them up, put dividers in so you don’t have long spans which will sag under the weight, screw/glue on 3/4×3/4 supports inside the carcase around the sides and back and screw/glue the shelves to that. Shouldn’t give you any problems.
-- Do or do not, there is no try
jackthelab
#8 posted 172 days ago
Renners- exactly what I was thinking -this will work to hold small items. The heavy machine parts that I have are already on the steel shelves that are in place. Thanks for your thoughts.
View bruc101's profile
bruc101
526 posts in 1712 days
#9 posted 172 days ago
For 1/2 inch osb shelves up to 10 inches wide and 48 inches long with 2 corbels. The more wight you use on the shelf the wider you want to make the front support…usually up to 2 inches for this width and length self.
Put a corbel on each end.
-- Bruce http://plans.testsitem3.info http://www.sawmillgirls.com
View dhazelton's profile
dhazelton
831 posts in 466 days
#10 posted 172 days ago
Problem is you offset the cost of buying 3/4 mdf or plywood by buying material to beef up the OSB. I’d just use another material and save the OSB for later. If you’re intent on using it doubling it up and putting a 1X2 across the front will probably suffice.
View teejk's profile
teejk
972 posts in 854 days
#11 posted 172 days ago
I hate OSB for anything other than verticle “paneling” that will never get seen
View REO's profile
REO
286 posts in 244 days
#12 posted 172 days ago
I have used 7/16 for shelving many times. For the garage I cut it 16” wide screw a 2×3 to the wall studs and make a face frame of 2×3. the openings are 16” tall and the uprights are 48 oc. the osb making the shelf is screwed to the 2x at the wall and th3 horizontals of the face frame and they do just fine. Most of the stuff I store in totes so the bottom of the tote actually carries the span load but I have had one opening with four 2 hp motors in it for three years. that one opening has only sagged 1/4” front to back the rest are still flat.
jackthelab
#13 posted 172 days ago
Hey,
Thanks for all the good ideas. I have about six full sheets of OSB and about 20-30 1×2s along with some other 1.5” pine. I see no reason that, with proper support, OSB can’t be used for the shelving material. I really don’t want to go out and buy more material – especially with all the stuff I currently have. It is a matter of using the material that I have on hand in an appropriate manner. Thanks for all the good ideas. If there is anything else out there, please feel free to let me know. I will post photos once finished. I am hurrying to get heat out in the workshop before it gets too cold to trench.
Thanks again!
