Natural Edge Table - Attaching the Leg(s)
Forum topic by rance posted 174 days ago 653 views 0 times favorited 4 replies Add to Favorites Watch
View rance's profile
rance
3856 posts in 1330 days
174 days ago
Topic tags/keywords: joining natural edge
Folks, I have purchased a lot of wood this last two weeks. Some of which will be used for a natural-edge table top. I’ve seen pictures of many of these. Of the ones I’ve seen, a LOT of them seem to have a hidden attachment. Most likely a mortise & tennon attachment.
My table top will be approx. 20×26 x 2” thick. I have to admit, M&T is not my strong suit. Fact is, I simply have not needed them in the woodworking I’ve done. I want this leg to fit very solid. I’ve seen the designs where there is a hidden wedge. Those are a one-shot thing. Maybe not the best joint for my skill level. Is this my only choice for a solid connection?
In addition, any suggestions as to a leg design? I’m guessing that a natural stump of some kind might look best, but I’m all for a more contemporary leg/base for it.
Anyone that can give me some first-hand advice on this would be truely appreciated. Thank you all.
View Monte Pittman's profile
Monte Pittman
7069 posts in 508 days
#1 posted 174 days ago
I do use M&T joints to put together my table bases. I still don’t particularly like doing them, and I am definitely not as good at it as I need to be. I am working my way up to making a full dining table. I have made tapered legs for them as well as using logs. Good luck.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
View HalDougherty's profile
HalDougherty
1820 posts in 1407 days
#2 posted 174 days ago
Here’s a couple of ways I fasten legs to my live edge benches and tables. The first one is just drilling a 1 1/2” hole with a forstner or spade bit, and inserting a leg with a tenon that I split on my bandsaw and drive in a wedge.
http://lumberjocks.com/projects/51216
Here’s the jig I made to cut the 1 1/2” tenons (any size could be made)
http://lumberjocks.com/projects/50958
And here’s how I make through tenons for a different style leg. I use the cut off corners of the leg as spacers for a quick jig that I clamp to the slab. Then I drill out most of the waste and use a router bit with a bearing to follow the jig. It only takes a few minutes to square up the mortise or round over the ends of the tenon. Then I cut a slot in the end of the tenon to drive in a wedge. I usually epoxy the legs as well as drive in the wedge so the legs won’t get lose over time.
Also look at other peoples projects, you’ll find a lot of different ways to attach table and bench legs. Good luck with your project.
Hal
http://lumberjocks.com/projects/37679
Hal
-- Hal, Tennessee http://www.first285.com
rance
#3 posted 173 days ago
Thanks Monte & Hal. One thing I was assuming was having a M&T, but not a through M&T. Other than using that hidden wedge, how else would you get it super tight? I’m now thinking that maybe a through tennon might be acceptable, but I don’t like the look as much. Hmmmm, decisions decisions.
Hal, that’s a cool use of the sawmill to get the legs level.
87228 posts in 1747 days
#4 posted 173 days ago
Here’s another thread on the subject.
http://lumberjocks.com/topics/14002
