Drawers - commercial slides or wood runners
Forum topic by Ben posted 173 days ago 1003 views 1 time favorited 26 replies Add to Favorites Watch
View Ben's profile
Ben
147 posts in 1026 days
173 days ago
Hi All,
About to start building my kitchen cabinets.
Option A: Build the drawer narrower and shorter than the opening to allow for undermount slides, then attach a second drawer front. Use through dovetails which I would either cut by hand or on the table saw.
Option B: Build it like a piece of furniture, with the drawer built tight to the opening minus the reveal, half blind dovetails and wood runners, and the front of the drawer box is exposed.
Option B might be cheaper, but then longer to cut the half blinds. And I’m not sure if the drawer action would be depressing.
Thoughts?
Thanks.
26 replies so far
View Howie's profile
Howie
2449 posts in 1092 days
#1 posted 173 days ago
Considering the amount of use a kitchen cabinet gets,I’d opt for the commercial slides. I like the wooden slides for bedroom type furniture. JMHO
-- Don't rollerskate in a buffalo herd
View teejk's profile
teejk
972 posts in 853 days
#2 posted 173 days ago
I’d go with option b (and you don’t need dovetails…dado will work…who other than you will know???). Option b will require some lube from time to time (paste wax works).
modern drawer slides are moving towards the “soft close” or “self close” and are relatively expensive plus are a PITA to install I think.
View John Ormsby's profile
John Ormsby
1235 posts in 1906 days
#3 posted 173 days ago
I use the accuride side mount slides and the Blum under mount soft close slides. It depends on the use. I also recommend you consider pull out trays in the lower cabinets. Better use of space and very convenient. The under mount slides are actually quite easy to install once you understand how they work.
It costs more up front, but is well worth it.
You also might consider buying the drawers pre-built or delivered knocked down where you glue them together. The modern equipment and suppliers of today can do it at reasonable costs and with great accuracy.
It is no big deal to add the drawer faces on the drawer boxes.
Also think about installing soft close door hinges. They are also worth it.
-- Oldworld, Fair Oaks, Ca
View cutworm's profile
cutworm
686 posts in 962 days
#4 posted 173 days ago
I’m with Howie.
-- "Actions speak louder than words but not nearly as often." - Mark Twain
View Ben's profile
Ben
#5 posted 173 days ago
Thanks guys.
This is for my own house, which I’ve been painstakingly working on for four years now and is a large part of my portfolio as a builder.
With that in mind, I really don’t want to order the drawers. You’re right that $19 is crazy cheap. But then again, it’s plywood with a 1/4” bottom. I want to do solid wood sides and a 1/2” bottom minimum.
I want to take my time, and make the nicest, most custom cabinets I possibly can.
When I open my drawers, I want to admire my dovetails, and I want potential future buyers of this house to feel the same.
Maybe this is crazy (probably), but what the hey.
I will do slide-out shelves, but I’m thinking basically the lowers will be chock full of drawers rather than doors anyway.
Thanks again.
View Clint Searl's profile
Clint Searl
847 posts in 530 days
#6 posted 173 days ago
Jonathan has it right, though I’d go for full extension self closing side mounts for both cabinets and furniture.
Side Note: Those who turn their noses up at commercial slides for furniture probably couldn’t fit up a drawer properly if their lives depended on it.
-- Clint Searl.............We deserve what we tolerate
View PurpLev's profile
PurpLev
7749 posts in 1817 days
#7 posted 173 days ago
for kitchen I’d go commercial slides. soft close is ideal if you can go for the extra cost.
View Ben's profile
Ben
#8 posted 173 days ago
About the only thing that appeals to me about the commercial slides, is that I would do through dovetails on the box (faster), and slap on a second face piece to fit the opening.
Do you guys think I’m insane for wanting to hand cut dovetails on about 10-15 drawers?
View Ben's profile
Ben
#9 posted 173 days ago
OK Jonathan – thank you.
So you have used that company before? (Or are you affiliated with them?)
Heck, I’d love to pay $20 just for the components milled to my spec’s.
View CessnaPilotBarry's profile
CessnaPilotBarry
603 posts in 279 days
#10 posted 173 days ago
I prefer Blum under mount, self and soft closing, full extension, hidden slides in kitchens. Wooden slides are perfect for traditional fine furniture, but not in modern kitchens, even if the kitchen won’t look modern.
I DO NOT like “pull-outs”, and lots of current kitchen designers agree… Why open a door to pull out a drawer? In any base cabinet where you’re considering pull-outs, consider changing to a deep drawer (or several). It’s also much easier to close a drawer with full hands, in a typical kitchen situation, than a pull-out / door combo.
BTW… I dovetailed my own kitchen, but I did a near-hand cut look with a D4R and variable spacing, using the smallest pins possible. If you really want to hand cut them, go for it. You’ll be really good at it when you’re done! ;^)
-- It's all good, if it's wood...
Clint Searl
#11 posted 172 days ago
With available glues, Titebond for instance, butt glued and screwed/pinned drawers are as serviceable as dovetailed assemblies. The only reason, IMO, to handcut dovetails is to elevate one’s self esteem. When I outsource drawers, it’s dovetails because that’s the only way they come, otherwise it’s glue and screw/pin.
View pintodeluxe's profile
pintodeluxe
1739 posts in 982 days
#12 posted 172 days ago
If I built more cabinets, I would make inset drawers. However, I would never use wood slides in a kitchen. Wood slides are really terrible – they stick, require waxing, and let the drawer sag too much. Plus they require additional blocking.
I have been very pleased with the look of centermount accuride slides. The slides are invisible even with the drawer open, allowing you to display your dovetail joints.
Oh, by the way – don’t cut them by hand – that is way too much work for a kitchen. Machine cut dovetils look just as nice, especially with a deep bit. See my forum on the topic below…
http://lumberjocks.com/topics/40073
View Cosmicsniper's profile
Cosmicsniper
2148 posts in 1327 days
#13 posted 172 days ago
So what you want, but wood slides would get old really fast.
-- jay, www.allaboutastro.com
teejk
#14 posted 172 days ago
I’ll chime in…1/4 ply for the bottoms should be more than adequate (but than again I don’t store my anvil in my kitchen). Hardwood runners are still present in pieces built a 100+ years ago.
My kitchen I used self-close side mounted ball-bearing slides that cost about $10/pair…a lot of cussing involved because the wife wanted the counter-top installed before I finished the face frames/drawers. Was very much a yoga thing.
View Dan Lyke's profile
Dan Lyke
1367 posts in 2294 days
#15 posted 172 days ago
I’m all for going all-out on the woodworking, but I’m a big fan of metal ball bearing slides in the kitchen. When I’m in the midst of cooking I want to be able to close drawers with a hip bump or a light kick. And kitchens get messy and have alternating humidity, which means wood slides will take a lot of tuning.
When we were deciding on a course of action, I bought a bunch of slides (and Accuride sent me a few) and I built some test rigs and tried 'em all out. We ended up with the Blum slildes, but those videos and notes might help you. Or they might just be more noise…. [grin]
