9 inch Radial Arm Saw blade... any suggestions?
Forum topic by StumpyNubs posted 171 days ago 1286 views 0 times favorited 27 replies Add to Favorites Watch
View StumpyNubs's profile
StumpyNubs
5029 posts in 967 days
171 days ago
Topic tags/keywords: radial arm saw
I have a couple radial arm saws and I want to dedicate one to just miter cuts. I want a good blade for it, somewhere in the under $150 price range. I know a lot of good 10 inch blades, but 9 inch is harder to find. Forest has one but they want near $300 for it and that’s just nuts.
Any 9 inch RAS or CMS users out there have a suggestion?
-- It's the best woodworking show since the invention of wood... New episodes Wednesdays at: http://www.stumpynubs.com
27 replies so far
View geoscann's profile
geoscann
258 posts in 447 days
#1 posted 171 days ago
STUMPY Question why do you want a nine inch set instead of a ten inch just curious
-- BIG geo ---Occam,s razor The simplist answer is often correct
34369 posts in 2567 days
#2 posted 171 days ago
Home Depot has a Freud 8-8 1/2 Framing saw blade for $17.00. They also have a 40 tooth for $30.00
I’ve used their 7 1/4” blades on my table saw and they cut beautifully. The 7 1/4” blade have 1/16” saw kerf
View Surfside's profile
Surfside
2277 posts in 340 days
#3 posted 171 days ago
try checking sears.com or www.searspartsdirect.com/
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View MrRon's profile
MrRon
1573 posts in 1410 days
#4 posted 171 days ago
I would check with www.carbideprocessors.com Didn’t see any 9” blades. May have to go with 8-1/2”
View shampeon's profile
shampeon
517 posts in 350 days
#5 posted 171 days ago
I got an Onsrud 8.5” negative rake blade off their eBay store for stupid-cheap money. It’s a quality blade.
820 posts in 660 days
#6 posted 171 days ago
For my Dewalt MBF, I bought the Ridge Carbide RS1000, and couldn’t be happier. It has a very small positive hook (2 deg., if I recall) which seems to work fine, and cuts very smoothly. The backup I bought was the “Freud 8 1/2 LU91, and in all honesty at less than 1/2 the price of the Ridge, is the better deal. It has a -5 deg. hook, which is my preference with an RAS. The Ridge is good, but still costly. A last choice would be the Forrest WWII, which can be had with a Mr. Sawdust grind. This is a triple chip tooth, and I think the hook has been relaxed. The Dewalt forum folks swear by this one, but they rip on their RAS, and I don’t. So I picked the ones I mentioned. In any case, the Forrest blade is by request and I believe ti to be within your price range.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
View DIYaholic's profile
DIYaholic
7288 posts in 842 days
#7 posted 171 days ago
Stumpy,
I also have a 9” DeWalt RAS and am interested in the outcome of your decision!!!
-- Randy-- I may not be good...but I am slow!
StumpyNubs
#8 posted 171 days ago
Geo- Some of the 1040’s and 50’s Dewalts were made to take a 9 inch blade. I think a 10” would fit, but only if you left the blade cover off… which is super scary with a radial arm saw!
9” blades shouldn’t so this hard to find in good quality since several companies make compound miter saws that take 9” blades.
I am a little hesitant to go with a box store blade because this is for miter cuts and you really need a high quality blade to make them accurately every time. I do a lot of miter cuts and don’t want to think about it. I just want to trust that they will be clean and straight.
View Alexandre's profile
Alexandre
1417 posts in 358 days
#9 posted 171 days ago
Stumpy, I know that freud blades are really good…
However, heres a 9 inch one that is soley crosscutting, as it has 72 teeth!
http://www.amazon.com/Freud-LU85R009-Ultimate-Cut-Off-PermaShield/dp/B0000225UT/ref=pd_sim_hi_5
heres a combo one: http://www.amazon.com/Freud-LU88R009-Crosscutting-Ripping-PermaShield/dp/B00004T7PR/ref=pd_sim_sbs_hi_1
-- My terrible signature...
#10 posted 171 days ago
Stumpy:
The frued 7 1/4 -24 tooth blade on my table saw polishes the cuts as far as I can tell is perfectly straight. I’ve used a blade to cut 1000 – 5/16×1 1/2×9” strips of Sapele for some coloring book carriers for the toy workshop. The wood was almost polished. The cuts didn’t require any sanding.
On my saw I can cut 1 5/8 thick with the 7 1/4” blade.
geoscann
#11 posted 171 days ago
STUMPY understood. I have a craftsman 12” radial arm saw thats set up for miter slots also. I like it because i can see what i,am do,ing and i don,t have to change everything over on my table saw.It works great. I bought the better or more expensive hf miter set i was very impressed with it. But back to your dilemma why not just use the 8” sets. I know you will loose some depth but how often do you really go more than an inch deep????
View RussellAP's profile
RussellAP
2394 posts in 453 days
#12 posted 171 days ago
I’m liking the Freud thin kerf blades these days. Nice cuts.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
Smitty_Cabinetshop
6377 posts in 785 days
#13 posted 171 days ago
Forrest Woodworker, $119.00
-- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive
View Tomj's profile
Tomj
197 posts in 548 days
#14 posted 171 days ago
I second the freud thin kerf blades even though I have a 10 inch Marples crosscut blade on my RAS right now which cuts beautiful by the way.
View markswoodcraft's profile
markswoodcraft
156 posts in 287 days
#15 posted 170 days ago
i know freud has some 9” combo blades kicking around in some stores
-- If time is money, then wouldn't an ATM be a time machine?
