Evolution of Power Tools
Forum topic by BDFan1981 posted 11-29-2012 03:43 AM 7955 views 0 times favorited 17 replies Add to Favorites Watch
View BDFan1981's profile
BDFan1981
99 posts in 2357 days
11-29-2012 03:43 AM
Topic tags/keywords: power tools evolution design
You folks ever wanted to know about the evolution of that one particular power tool?
Examples of power tools with one model number that went through different design changes:
Skil 534 6-1/2” Saw = produced 1966-85, replaced by 5125 in late 1984. Originally 3-wire (grounded), motor was double insulated in late 1976 (type 8).
Evolutionary picture (from eBay):
(note the double-insulated version of the tool is the one that is torn apart)
Skil 574 7-1/4” Saw = produced 1966-85, replaced by 5150 in 4th qtr. 1984. Originally 3-wire (grounded), motor was double insulated in late 1976 (type 8).
Early version (brushed chrome motor housing):
Later version (dark gray motor housing; double insulated, 1976-77 production, UL symbol and warning text on nameplate instead of separate decals):
Much later version (note slightly different text design, 1977-82 production):
(this example was made in October 1981 going by the date code)
Final version (company city/state and specifications move to black portion of decal, 1982-84 production):
(this example was made in November 1982)
EDIT 1-18-2013: See changes.
~Ben
17 replies so far
View Handtooler's profile
Handtooler
1578 posts in 2159 days
#1 posted 11-29-2012 11:24 AM
Very Interesting! You are sure on top of your game.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View Purrmaster's profile
Purrmaster
915 posts in 2120 days
#2 posted 11-29-2012 11:55 AM
Interesting. Did the specifications on the models change as well? Horsepower, amperage, etc?
BDFan1981
#3 posted 11-29-2012 12:15 PM
Re: Purrmaster
Yes. Originally, the RPM was 5700 on the older versions (with the 3-wire cord), and the double-insulated motor versions (2-wire cord) had the motor rated down to 4600 RPM.
Ironically, however, on the box for the Type 6 version (3W cord) the RPM is 5700, when on the Type 7 version (again 3W cord) the RPM is 5300.
Picture 1:
Picture 2:
This is odd: the box says the machine is a Type 6, but the actual tool is a Type 7.
~Ben
View Surfside's profile
Surfside
3389 posts in 2200 days
#4 posted 11-29-2012 04:46 PM
Excellent post!
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
BDFan1981
#5 posted 01-18-2013 09:02 AM
I want to let you folks know that Skil did not emboss the date code on the tool’s nameplate until late 1978. Before then, the date code could be found on a separate decal located elsewhere on the tool. These decals could get lost as the tool ages, so be sure to take good care of any of these pre-1979 Skil power tools which still have them to this day. The date code was also stamped on the box.
~Ben
Purrmaster
#6 posted 01-18-2013 10:27 AM
Good information. Please keep it coming.
BDFan1981
#7 posted 02-05-2013 11:03 PM
More: on some of their “Super Duty” or “Heavy Duty” circular saws (sidewinder design) the date code may instead be found on the decal applied to the upper blade guard.
(from a model 553 made 10/83)
(model 866 made 4/80, this one was really used and abused, so much that the main handle is broken)
~Ben
runswithscissors
2767 posts in 2052 days
#8 posted 02-06-2013 06:47 AM
I am wondering if the rpm ratings were for the blade speed rather than motor speed. If so, would that indicate a difference in gearing (I don’t think any of those were/are direct drive)? Just curious.
BDFan1981
#9 posted 02-06-2013 07:15 AM
I am not an expert there although I can point out the 6-1/2” blade size models do run at a slightly higher RPM than do the 7-1/4” units, and while most 8-1/4” units may run at the same motor speed as the 7-1/4” units, some others may have still reduced motor speeds, and the big 10-1/4” saws have a further reduction in motor speed to match the speed of the motor to the size of the blade in relation to the blade tip speed factor.
HEAVY DUTY SIDEWINDERS
552, 5625 = 6-1/2”, 5800 RPM = 9870 FPM
553, 5650 = 7-1/4”, 5200 RPM = 9870 FPM
554, 5665 = 8-1/4”, 5200 RPM = 11,231 FPM
DROP FOOT SIDEWINDERS
807, 5750 = 7-1/4”, 5800 RPM = 11,009 FPM
808, 5765 = 8-1/4”, 5800 RPM = 12,527 FPM
810, 5790 = 10-1/4”, 5200 RPM = 13,954 FPM
WORM DRIVE SAWS
367, 5825 = 6-1/2”, 4600 RPM = 7828 FPM
77 = 7-1/4”, 4400 RPM = 8351 FPM
825, 5865 = 8-1/4”, 4300 RPM = 9287 FPM
It should be noted that the worm-drive saws are geared much lower to deliver higher torque levels.
~Ben
BDFan1981
#10 posted 03-03-2013 02:49 AM
I want to revive this thread as to point out the following about warning label texts:
In the year 1977, the specifications text looked like this, for example:
(black border)
SKILSAW® (trade name in red text)
7-1/4” Circular Saw
574
(red border)
120 Volts A.C. only – 25-60 Hz.
10 Amps – Type 8 – 4600 RPM
When servicing use only
identical replacement parts. (UL logo/Listed 293G text)
CAUTION: For safe
operation see manual.
SKIL CORPORATION
CHICAGO, ILLINOIS – Made in U.S.A.
It was stylized like this for 1978:
(black border)
SKILSAW® (trademark in red text)
7-1/4” Circular Saw
574
(red border)
120 Volts A.C. only – 25 to 60 Hz
CAUTION: FOR SAFE OPERATION SEE
MANUAL. WHEN SERVICING USE ONLY
IDENTICAL REPLACEMENT PARTS.
SKIL CORP. (UL symbol at right with “Listed” and “293G” on top and bottom of circle respectively)
Chicago, Ill. – Made in U.S.A.
It was then changed to look like this from 1979-81:
(black border)
7-1/4” Circular Saw
574 (UL symbol with “Listed” and “293G” at top and bottom of circle respectively)
(red border)
120 VOLTS – AC ONLY – 25-60 Hz
10 AMPS – TYPE 8 – 4600 RPM
CAUTION: For safe operation
see manual. When servicing use
only identical replacement parts.
SKIL CORP.
CHICAGO, ILL.
Made in USA (date code embossed at right)
In 1982, it then looked like this:
(black border)
7-1/4” Circular Saw
574 (UL symbol with “Listed 293G” at bottom; this is all to the right of the tool model #)
(red border)
120 Volts AC only 25-60 Hz – 10 Amps
4600 RPM – Type 9
CAUTION: FOR SAFE OPERATION SEE MANUAL. WHEN
SERVICING USE ONLY IDENTICAL REPLACEMENT PARTS.
WARNING: CHECK LOWER BLADE GUARD BEFORE EACH USE.
SUPPORT WORK FIRMLY. USE ONLY RECOMMENDED SIZE
BLADES. WEAR EYE PROTECTION.
DANGER: KEEP HANDS AWAY FROM BLADE.
SKIL CORP. – Chicago, Ill. – Made in USA (date code embossed at right)
For 1983-84, it looked like this:
(black border; tool specifications are moved here)
7-1/4” Circular Saw
574 (UL symbol/Listed 293G text to the left of tool model #)
4600 RPM – Type 10
(red border)
WHEN SERVICING USE ONLY IDENTICAL REPLACEMENT PARTS.
USE ONLY RECOMMENDED SIZE BLADES.
SUPPORT WORK FIRMLY. WEAR EYE PROTECTION.
DANGER: KEEP HANDS AWAY FROM BLADE. (date code embossed at right)
~Ben
View oldnovice's profile
oldnovice
6901 posts in 3394 days
#11 posted 03-03-2013 07:39 AM
Ben was Skills Inc. Purchased by Bosch and did Skill private label any models for other companies/store brands?
BDFan1981
#12 posted 03-03-2013 07:05 PM
@oldnovice
Skil was acquired January 3, 1979 by Emerson Electric. In 1992, Robert Bosch acquired a 50% stake in Skil, forming Skil-Bosch (S-B) Power Tool Co. Four years later (in 1996), Robert Bosch acquired Emerson Electric’s 50% share of Skil, and as a result the company was renamed Robert Bosch Tool Co. around 2000.
~Ben
BDFan1981
#13 posted 03-27-2013 01:37 AM
Two generations of the model 537. This is said to be the first Skilsaw to make the transition from 3-wire to 2-wire, circa 1968.
Type 2 (3-wire/all metal housing)
Type 3 (2-wire/double insulated motor)
~Ben
BDFan1981
#14 posted 04-05-2013 03:43 AM
Shoot, that last 537 I mentioned (gray plastic motor housing) is actually a Type 6 unit.
Anyway, here is a Type 10 model 537 saw, with the dark gray plastic housing (obviously circa 1971-1977):
~Ben
View Nicky's profile
Nicky
695 posts in 4119 days
#15 posted 04-05-2013 04:01 AM
Interesting history. I was not aware of the variants.
Bought my 574 type 10 mid-eighty’s. The saw has been used on every load of rough lumber and every sheet of ply I’ve ever purchased. Built additions, sheds, roofs and many other projects. Still in perfect working order, still looks good.
-- Nicky
