How do I get measurements out of sketchup?
Forum topic by derosa posted 11-29-2012 01:29 AM 1170 views 0 times favorited 5 replies Add to Favorites Watch
View derosa's profile
derosa
1590 posts in 3070 days
11-29-2012 01:29 AM
I found this sketchup and my wife really likes it to the point I can start on it, problem is it is useless to me because I can’t for the life of me figure out how dimensions are determined. Actually I’ve never figured out sketchup ever. So any pointers or tips?
-- A posse ad esse
5 replies so far
View JSB's profile
JSB
737 posts in 2312 days
#1 posted 11-29-2012 01:41 AM
I would suggest this website. It has everything you need for sketchup for woodworking. There is a video on there dedicated to dimensioning. Once you get the basics it is truly a GREAT tool for design.
http://sketchupforwoodworkers.com/
-- Jay - http://www.jayscustomcreations.com
View oldnovice's profile
oldnovice
7378 posts in 3602 days
#2 posted 11-29-2012 01:44 AM
Use Creo and start over, it can give you dimensional prints of each part and the entire assembly. I you don’t want to try it send it to me and I’ll do it for you!
View PurpLev's profile
PurpLev
8548 posts in 3883 days
#3 posted 11-29-2012 02:16 AM
there is no need to start over with anything… SketchUp can get you dimensions.
depending on what you want to accomplish there are several ways to go about it, but to get you started, you can select the “Dimensions” tool (from menu “tools”), then either click on a line in the drawing – in which case it will provide you with it’s length, or click 2 intersections/points in the drawing and it’ll provide you with the distance between them:
derosa
#4 posted 11-29-2012 03:52 AM
Turns out after some searching that the whole set is ripped off from Wood magazine, thanks for the answers but I think I’ll get them from Wood. I have a friend with the whole collection and I don’t have to steal it.
-- A posse ad esse
View MTC_Est_2012's profile
MTC_Est_2012
9 posts in 2241 days
#5 posted 11-29-2012 04:02 PM
Rev Russ,
You can determine the dimension either with a dimension tool or by using the tape measure. The dimension tool will put a dimension in the model the tape measure just displays the dimension in the status bar at the bottom.
Another caution is that either way you do this (dimension tool or tape measure) you must make sure you are “on axis” or you will not get accurate information. You will know if you are on axis because the dotted line between the points you pick will be red, blue or green.
Also, when adding dimensions (for example dimensioning the height of a table from the bottom of a leg to the table top) if the two points you pick on the model are not directly above/below each other you will not get accurate dimensions. So, in my example if the table top extends out over the leg you will have to first use the tape measure to create a point to dimension to.
Hope this is not too confusing.
Mark
