Polyurethane On Stain - What's Your Preference - Steel Wool or Sandpaper?
Forum topic by Bingo969 posted 178 days ago 912 views 0 times favorited 9 replies Add to Favorites Watch
View Bingo969's profile
Bingo969
7 posts in 323 days
178 days ago
Howdy -
I’m curious to hear what people’s thoughts on this are. I know only a few other local woodworkers and it seems everyone has a different answer but not many can really explain why they feel that way.
I make large-ish wooden box drums (Called a ‘Cajon’ if you are familiar with them or want to see). Here is a picture of my first one that I thought came out so-so. A little warp on the front soundboard down near the bottom. The top corners are supposed to have a gap there for the traditional wood-on-wood “crack” sound when struck. http://www.livesuncoast.com/Cajon.jpg
I’ve been staining them (Oil based stain made by Zar. I really like how it comes out) and then polyurethane that with a water-based poly. Seems to work really well. I’ve played around with matte, satin and gloss poly and I’ve more or less settled on the satin for a nice halfway between dull and really shiny.
I’ve been using 1200-1500 grit sanding inbetween each coat of poly. I usually end up around 4-6 coats total before I’m calling them done.
However, some have sworn by using 4-0 steel wool between coats of poly. I’m not sure I’m happy with the results. I seem to find more “swirls” using the steel wool. However, maybe I’m doing it wrong too.
So what are you thoughts on Steel Wool vs Sanding and why? What are your experiences? I’d love to hear them and help educate myself more on different techniques.
As always, thanks for being such a great resource for us new woodworkers!
Bingo
9 replies so far
View Cosmicsniper's profile
Cosmicsniper
2150 posts in 1331 days
#1 posted 178 days ago
Try 3M sanding pads.
You don’t need anything too severe. Just enough to remove dust nits and to give a little mechanical advantage for the poly to grab onto.
-- jay, www.allaboutastro.com
View Earlextech's profile
Earlextech
601 posts in 863 days
#2 posted 177 days ago
Use steel wool on solvent based poly only, use 3M pads on water based poly.
-- Sam Hamory - The project is never finished until its "finished"!
831 posts in 665 days
#3 posted 177 days ago
If you’re happy with what your results with the current, no reason to change. But if you do change for some reason, do not go to steel wool…..especially with waterborne finishes.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
14866 posts in 2390 days
#4 posted 177 days ago
I just find steel wool easier than sandpaper, but it’s really as simple as trying both and sticking with the one you like best. I have heard, though, that steel wool should NOT be used with water-based poly because of the possibility of steel remnants rusting in the finish.
View Clint Searl's profile
Clint Searl
851 posts in 533 days
#5 posted 177 days ago
After getting rid of the nubs left by the first coat, sanding between successive coats is a waste of effort. Follow-on coats should level out by themselves. When you get the desired build, wait a couple days, and rub out with 0000 steel wool and cheap paste wax.
Also, what’s the point of laying waterborne on top of oil poly? Drop the oil poly and put the waterborne directly on the cured ZAR. It works perfectly; that’s exactly what I do.
-- Clint Searl.............We deserve what we tolerate
View ETwoodworks's profile
ETwoodworks
92 posts in 865 days
#6 posted 177 days ago
I like #00 steel wool but i only use solvent based poly.
-- Building quality in a throw away world.
View Charles Maxwell's profile
Charles Maxwell
826 posts in 1979 days
#7 posted 177 days ago
No question about it – - – Quad Naut (0000) Steel wool! I swear by it.
-- Max the "night janitor" at www.hardwoodclocks.com
View Grandpa's profile
Grandpa
2381 posts in 848 days
#8 posted 177 days ago
I always leave little pieces of steel wool on the project…...someplace. They only show up after the next coat is applied. I never use it because of this. After the last coat if I need some smoothing I might go to steel wool but not between coats. Just my way of doing it. I sand between coats if there is much lapse time between them.
Bingo969
7 posts in 323 days
#9 posted 177 days ago
Interesting. So it looks like the consensus here is about as split as with the few people I’ve spoken with around here as well. Ha. Goes to show everyone has a different approach I guess.
It does sound like I had the right idea though, to go with sandpaper since I’m using a water-based poly.
I definitely appreciate all the feedback.
