Furniture repair - chip out
Forum topic by james3one posted 203 days ago 452 views 0 times favorited 5 replies Add to Favorites Watch
View james3one's profile
james3one
37 posts in 969 days
203 days ago
Topic tags/keywords: mahogany cherry refurbishing
Was removing one of hundreds of staples from the back of this chair. As the staples were longer that needed it required some prying. This one slipped and knocked a chip out of the back. This is clearly visible and I need to make the repair.
Plan is to use some wood glue, with a little pigment added. Set the chip back in til the glue sets up. Light sanding around the edge of the chip with 400 grit or higher. touch up with dye and finish with dark wax.
If anyone has better idea or correction to this please let me know.
j
-- James, Tulsa OK,
5 replies so far
View Tyler's profile
Tyler
52 posts in 209 days
#1 posted 203 days ago
glue it back…lol looks like a small piece
-- You can get alot further with a kind word and a hand gun, than just a kind word alone
89108 posts in 1774 days
#2 posted 203 days ago
If you use white glue it dries clear.
View Fishinbo's profile (online now)
Fishinbo
4914 posts in 373 days
#3 posted 203 days ago
Just glue it back neatly and evenly.
View huff's profile
huff
2597 posts in 1482 days
#4 posted 203 days ago
James,
It looks like it chipped out with nice clean edges. Do a dry fit first, but it should go right back and with a little glue should not be that noticable. The more you sand and fool with the original finish the more it will stand out like a sore thumb. Like Jim said, if you use white glue, it dries clear. Be careful with clamps as not to damage the surface. Good Luck
-- John @ http://www.thehuffordfurnituregroup.com
View Grandpa's profile
Grandpa
2399 posts in 873 days
#5 posted 202 days ago
What a1Jim said. Good luck.
