Which Hand Plane?
« back to Hand Tools forum
Forum topic by javaboy posted 178 days ago 682 views 0 times favorited 15 replies Add to Favorites Watch
View javaboy's profile
javaboy
102 posts in 306 days
178 days ago
Topic tags/keywords: question plane
I use power tools for 98% of all my woodworking operations and am quite happy with that method of work. Sometimes I do think a handplane would be useful. So here is the question:
What is a good choice of handplane for someone who is a dedicated power tool user? Which type of plane would be most useful for general type work in a power tool environment?
-- Sow justice, reap peace
15 replies so far
View bondogaposis's profile
bondogaposis
1254 posts in 522 days
#1 posted 178 days ago
I would go w/ a low angle block plane. An old Stanley 60 1/2 is ideal. If you are going to get a new plane then look at Veritas or LN. Don’t mess w/ the new Stanley’s as they are junk.
-- Bondo Gaposis
View chrisstef's profile (online now)
chrisstef
5299 posts in 1178 days
#2 posted 178 days ago
Id be willing to bet a small block plane, well 2 small blocks, would serve you well. Something for planing end grain and something for just trimming a hair off. Id go vintage peronally and go with Stanley 9 1/2 and a 60 1/2 for the end grain. They do make them new, and they are fairly inexpensive.
I find that with power tool use i am usually just a few hairs off and the little bit of planing will sneak right up on a perfect fit.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
View BTimmons's profile (online now)
BTimmons
1101 posts in 656 days
#3 posted 178 days ago
I’d say that a smoothing plane such as a Stanley #4 is indispensable, as well as a good block plane. The smoothing plane can remove the machining marks left by the jointer and planer, also any burn marks from the table saw. The block plane is good for smaller detail work, and the low angle ones are great for attacking end grain.
-- Brian in Arlington, TX - Laziness is the foundation of efficiency.
View David Craig's profile
David Craig
2127 posts in 1280 days
#4 posted 178 days ago
As a power tool user, most of what you would use a plane for is cleaning up of any power tool marks. Good planes for this are as follows -
Block plane – Good first choice because these are used to clean up saw marks on edge grain (Low angle block plane is used on end grain) and produce a chamfer to take down hard edges. Another advantages is they are usually the least expensive plane you will buy.
Smoothing Plane – Useful for reducing the need for power sanding. Use it to smooth surfaces with very light passes. Less sanding, less clogging of wood pores and makes for a more pleasant surface.
Shoulder Plane – Good for cleaning marks off of tenons, rabbets, out of dadoes, etc. Good one to have if you do a great deal of joinery.
View Don W's profile
Don W
9970 posts in 739 days
#5 posted 178 days ago
I agree with a block plane. Even most carpenters have a block plane in their pouch. Its a must for any kind of woodworking task.
I like vintage. Almost any vintage block with an adjustable mouth will get you what you need to start with.
Then a smoother, a #3 or #4.
javaboy
#6 posted 178 days ago
Thank you all for your thoughtful suggestions—they are greatly appreciated!
View AdmiralRich's profile
AdmiralRich
2 posts in 697 days
#7 posted 176 days ago
Whatever you buy, you’ve got to know what “sharp” is, and how to achieve sharpness, as planes are nothing more than jigs that hold an edge tool. Any plane with an iron that’s not truly sharp will be a frustration for a first time user.
-- Elvem ipsum etiam vivere
View Arminius's profile
Arminius
219 posts in 1975 days
#8 posted 176 days ago
Block plane is ideal. Smoother is pretty good.
I would therefore recommend a Low Angle Jack (Lie-Nielsen, Veritas, now Stanley though I have no experience with the model). There is basically nothing you cannot do with one other than the tight joinery work of a shoulder plane, it works as a very large block plane, it is long enough to work on jointing, and they are great smoothers. They are the classic ‘desert island’ plane.
javaboy
#9 posted 176 days ago
”Whatever you buy, you’ve got to know what “sharp” is, and how to achieve sharpness, as planes are nothing more than jigs that hold an edge tool. Any plane with an iron that’s not truly sharp will be a frustration for a first time user.”
A big 10-4 on that AdmiralRich! Right now my most used hand tools are a set of cheap Sear Craftsman chisels. I worked hard flattening their backs and keeping them razor sharp—that transformed them from worthless junk into functional tools.
View NiteWalker's profile
NiteWalker
1482 posts in 748 days
#10 posted 176 days ago
I’m also a primarily power tool woodworker. I went with the veritas low angle block plane. Spendy, but well worth it. The apron plane is nice too and a bit less.
A vintage low angle block refurbed by one of the guys here or on woodnet would be a good choice too.
View Surfside's profile (online now)
Surfside
2287 posts in 345 days
#11 posted 176 days ago
Interesting discussion. I’d go for block plane too! Watch this video .
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View 12strings's profile
12strings
186 posts in 556 days
#12 posted 175 days ago
I’ll be an oddball out and suggest that if you’re willing to spend the money, a Veritas small bevel-up smoother would be great…Here’s why:
with the 100+ pricetag of the new nice block planes, you can pay 50-60 more and get a plane that has end-grain capabilites due to the bevel-up design, but also works for general smoothing.
Of course, you can find a good vintage block plane for really cheap. That’s where I would go based on money reasons,
-- I'm strictly hand-tool only...unless the power tool is faster and easier!
View HorizontalMike's profile
HorizontalMike
4933 posts in 1085 days
#13 posted 175 days ago
IMO, you need at least three (in my priority preference):
1. Low angle Block Plane
2. #6 Foreplane – with a high quality blade
3. a Shoulder Plane #92 or #93
Oh FWIW, I have a decent #4 and find myself NOT using it in favor of the #6, when I need to use a hand tool to assist with a project.
javaboy
#14 posted 175 days ago
Lots of food for thought in this thread. Good to see a consensus on the low angle block and smoother planes, but also interesting to see the alternatives suggested and the reasons why.
Thanks to everyone for all the good advice—it is greatly appreciated!
Smitty_Cabinetshop
6405 posts in 790 days
#15 posted 175 days ago
+1 vote for a good smoother, typically a #4. Then a jack. Then a block.
Blocks are fun, it’s easy to get too many of them once you start, but they are not as useful for me as others find them. Especially if you have a bench and are working from there. Blocks are made for one-handed use, hence Don’s very accurate observation about carpenters having them in the field. But if you’re at a bench, you can just as quickly knock off corners and clean up edges with a sharp smoother and two hands.
If you get into wanting to take more material each pass than what your smoother will do, a jack is next. It usually has an open mouth and is designed to hog off material quickly.
Good luck as you move along the hybrid path!
-- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive
