Saw anvil?
« back to Hand Tools forum
Forum topic by Brett posted 177 days ago 501 views 0 times favorited 5 replies Add to Favorites Watch
View Brett's profile
Brett
603 posts in 853 days
177 days ago
Last time I checked, my local Wal-Mart was fresh out of cast iron saw anvils (like this one shown below):
(EDIT: The workbench is not mine.)
I have an old dovetail saw that I’d like to restore, but I think I will need to flatten the blade a little on a saw anvil. Does anyone have suggestions for a modern, affordable substitute for a saw anvil?
-- More tools, fewer machines.
5 replies so far
View exelectrician's profile
exelectrician
1004 posts in 597 days
#1 posted 177 days ago
A two foot piece of train rail.
Nice rising DT’d leg on you workbench by the way.
-- Love thy neighbour as thyself
View crank49's profile
crank49
2288 posts in 1141 days
#2 posted 177 days ago
Train rail will get you the mass, but the top is crowned, not flat.
A piece of Flat Bar or square bar would be nice and it comes in widths from 1” up to 6” and in thicknesses from 1/4” to 4”.
Steel weighs roughly .29 lb per cubic inch.
So, if you want a 25 to 30 lb block you will need about 86 to 103 cubic inches.
If you start with 2” thick x 4” wide that is 8 cubic inches per inch of length.
So a 12” long, 2” x 4” flat bar will contain 96 cubic inches; and weigh 27.8 lbs.
I think this would be the minimum chunk you would want to use.
Any steel supply house should be able to sell you a piece of flat bar like this for $0.50 to $0.70 per pound.
They will probably charge you a cutting fee as well.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View Loren's profile
4887 posts in 1818 days
#3 posted 177 days ago
I buy short metal bars on ebay sometimes. Prices can
be very good as they are scrap and thus no cutting
fees.
Shipping is often reasonable too as a small but heavy
steel bar still fits in a small priority mail box.
bandit571
3647 posts in 853 days
#4 posted 177 days ago
About that train rail 1) IF you can find some LEGALLY they do work. 2) The bottom of the rail is flat, merely use the top in a vise.
Again, LEGALLY find rail, as these usually belong to some Rail Road. If you know a MOW crew member, ask them for any short scraps of rail. MOW? Maintainence Of Way. These are the folks that work on keeping the rails in good order.
View Dave's profile
Dave
9187 posts in 1010 days
#5 posted 176 days ago
An I beam cut off from a construction site. Any old heavy table top off heavy machinery.
