Lathe chisels and gouges, which one?
Forum topic by RussellAP posted 174 days ago 295 views 0 times favorited 1 reply Add to Favorites Watch
View RussellAP's profile
RussellAP
2394 posts in 453 days
174 days ago
I have a pretty good set of chisels with a couple bowl gouges parting tool, spindle gouge and a skew.
I’m going to make some bowls and I need a good tool to hollow out the bowl. It seems everything I have wants to be thrown to the outside of the bowl when I turn it and I cant get it smooth. I think one of the problems is the dry walnut I’m using. I’ve heard it’s much easier to turn green wood.
So can you recommend a good tool to hollow out the bowls? I need to know what it’s called so I can look around at several brands before I buy.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
1 reply so far
View Kreegan's profile
Kreegan
1302 posts in 313 days
#1 posted 174 days ago
Are you drilling a pilot in the middle of the bowl with a drill? I’ve watched Richard Raffan do that, and then use a round nose scraper to hollow the bowl. I think that’s also a large part of what you use a bowl gouge for. Generally gouges are used for removing material, so it stands to reason that’s what you’d use a bowl gouge for. I’ve not turned any bowls yet, just watched videos, so take my advice with a giant nugget of salt.
Rich;)
-- Rich;) -"Dada make a big mess?" "Yes Dada made a big mess."
