Tablesaw help - Direct Drive Vs. Belt Drive
Forum topic by GlennsGrandson posted 178 days ago 902 views 0 times favorited 6 replies Add to Favorites Watch
View GlennsGrandson's profile
GlennsGrandson
414 posts in 479 days
178 days ago
Topic tags/keywords: direct drive belt drive tablesaw
I am in the market for a good used TS with a bigger cast iron top.
Can someone please give me their opinions on direct drive vs. belt drive tablesaws? The only thing that I’ve heard is that belt driven is quieter (I have a cheap small direct drive, sounds like a jet). Is one recommended over the other?
Thanks for helping!
-- Grant - S/N Dakota
View ShaneA's profile
ShaneA
3967 posts in 768 days
#1 posted 178 days ago
Belt driven induciton motor is typically seen as superior, quiter, longer life span, and more torque…unless mobility from job site to job site is a factor for you, not too many reasons to go for the universal motor. Not sure you can get a cast iron top with the universal motor.
View Monte Pittman's profile
Monte Pittman
7069 posts in 508 days
#2 posted 178 days ago
I have belt driven. Don’t think i have ever had the other. Really like mine though.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
View MonteCristo's profile
MonteCristo
2061 posts in 358 days
#3 posted 178 days ago
Can’t think of a table saw of any size/power that is direct drive. Also, with direct drive you want to move quickly if you jamb the saw blade and it stops turning, otherwise you will end up with a “no-drive” TS, ie. it will burn out the motor. With a belt driven saw the belt (supposedly) will slip when the blade stalls.
View crank49's profile
crank49
2288 posts in 1141 days
#4 posted 178 days ago
I think Sears had a contractor’s saw one time that had a cast iron table and a universal direct drive motor.
They tried to promote the direct drive as an advantage stating things like high efficiency and no belts to get loose and things like that. They also claimed it was a 3hp saw, which is obviously BS, since it ran on a standard 120volt outlet.
Most people must have seen this marketing ploy for what it was, a way to sell a cheap universal motor in a table saw, and stayed away because they dropped the campain about as fast as it popped up.
In answer to your question, all direct drive saws hang the blade directly on the motor shaft and use universal, brush type motors. There are a few really well respected saws that use this design, like the Bosch, Dewalt, Ridgid, Porter Cable etc. jobsite type saws, and they are good saws, but cost almost the same as the hybrid class cabinet saws; about $500 to $600. Their main purpose is to be portable.
Much more common in the direct drive saw genre are the $100 to $200 Ryobies and Skil, and generic labeled variations. These saws serve a market where longevity is not a primary concern. They work, but they don’t have the bearings and beef to hold up to continuous professional use.
A table saw with a cast iron table, standard miter slots, belt drive induction motor is just a much more stable and quiter, and longer lasting option.
a f
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
GlennsGrandson
#5 posted 178 days ago
Enough said, thanks for all of the input guys!
Belt it is.
View knotscott's profile
knotscott
4201 posts in 1545 days
#6 posted 177 days ago
Here’s some info if you’re interested. Table Saw Classifications
