Is it safe to drill out a rare earth magnet?
Forum topic by Jonathan posted 11-25-2012 07:11 PM 8056 views 0 times favorited 15 replies Add to Favorites Watch
View Jonathan's profile
Jonathan
2609 posts in 3290 days
11-25-2012 07:11 PM
Topic tags/keywords: mahogany ebony inlay ebony inlay epoxy inlay epoxy forstner bit rare earth magnet neodymium magnet countersunk
The area in-question is the left inlay.
I have a project that I want to finish up soon, and was almost done until I ran into a problem. I drilled 6-holes in the back of a piece of mahogany, then glued-in a neodymium magnet into each hole, slightly countersunk below the surface, around 1/16” or so. I say “or so” because I used a forstner bit in a handheld drill, and the wood is at an angle, so it was a little difficult to get everything exactly the same. Looking back, I should’ve taken the time to setup my drill press, but I was in the middle of something with it as well, so I decided to just use the handheld drill. At any rate, after the magnets were in and the glue was dry, I sanded down a little bit of an ebony pen blank, then mixed the ebony dust with epoxy to fill the holes. I filled all the holes slightly overflowing, then let it cure. I then took the project over to my Rigid oscillating sander and tried to slowly sand everything flush. Well, the magnet in the picture was apparently the high magnet of the group and I barely sanded through to the surface.
Now, this is the back of the piece, and it’ll rarely be seen anyway, but I am of the opinion that the entire project should be completed to the same level of quality, so I’d like to fix this. I’m wondering if it is safe to try and slightly drill out a little of the magnet? I don’t want to drill the whole thing out, just a small portion of it, then refill with the ebony/epoxy mix, and fix the mistake.
Are neodymium magnets OK to drill? I can’t think of any other way, other than trying to use some sort of paint or something to cover the magnet, but then this 1-inlay won’t match the other 5-inlays.
Any other suggestions will also be considered. I also thought about simply cutting a super-thin piece of mahogany as a veneer, then gluing it onto the back to just cover everything up and be done with it. Any thoughts? I’d like to keep the 6-inlays looking good, if possible, but at this point, I also just need to finish the project.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
15 replies so far
View johnstoneb's profile
johnstoneb
3072 posts in 2412 days
#1 posted 11-25-2012 07:46 PM
It would be best to pop out the magnet and drill a little deeper and glue back in . Heat the magnet with a heat gun that should soften the epoxy and pry out the magnet.
Those magnet are very hard and probably won’t drill very easily.
-- Bruce, Boise, ID
View css's profile
css
3 posts in 2248 days
#2 posted 11-25-2012 07:50 PM
I could be wrong but if it is what I think it is it is harder then a drill bit.
Jonathan
#3 posted 11-25-2012 08:00 PM
@Bruce,
Thanks for the response! I will try heating the epoxy with my heat gun after I’m off work and at home to give this a try. Hopefully that’ll soften it up enough to remove it. It’s Gorilla Glue Epoxy, as I had it left over from something else. I’ll just have to really be careful when re-drilling, as the wood is super-thin on this portion of the project. I’ll have to check the depth of the hole vs. the thickness of the wood now, since the forstner bit’s tip may end up poking through. If that’s the case, I think I’ll simply drop in a smaller magnet since they’re slightly thinner. Won’t have the same holding power, but it should still be fine.
@css,
You may be right. I wonder if I could sand the magnet down slightly to thin it out? Hopefully the above solution will work.
Thanks again for the quick responses.
Jonathan
#4 posted 11-25-2012 08:01 PM
I’ll report back after I try heating the epoxy to see if it’ll soften enough to scoop everything out of the hole.
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3825 days
#5 posted 11-25-2012 08:03 PM
The truth is heat and magnets don’t go well the magnetism becomes lost with heat,so you would need to use plenty of coolant and a tungsten or diamond drill.I would redo the holes if I were you. Alistair
View DannyB's profile
DannyB
46 posts in 3661 days
#6 posted 11-26-2012 05:56 AM
The magnets should not be harder than the drill bit, if it’s a good HSS drill bit (or carbide bit)
Neodymium itself is not very hard, about 25-28 HRC, but neodymium magnets are neodymium-iron-boron. As a combination, they have a vickers hardness of between 550-650, which is ~53-57HRC.
A good HSS drill bit is at least 60 HRC.
So drilling them would be mighty painful, but should work. You’d be better off drilling them with diamond, and at that point, i would just make slightly larger holes as SCOTSMAN suggested.
Sanding them is going to be quite difficult, normally you’d grind them or something. Imagine trying to thin out a piece of HSS steel with sandpaper. It’s doable, but not something i’d want to do.
As for the heat issue, it’s actually a long and complex topic, but for neodymium, the short answer is it’s entirely possible to cause irreversible but recoverable (IE lost until remagnetized) loss in neodymium magnets using only a heat gun
View Mosquito's profile
Mosquito
9568 posts in 2532 days
#7 posted 11-26-2012 06:05 AM
Also keep in mind that anything that you do happen to drill out, would likely stick to the magnet very strongly… and may be difficult to remove.
-- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com
View Greg's profile
Greg
332 posts in 3113 days
#8 posted 11-26-2012 09:26 AM
Jon, I use a lot of these mags, and I was told NEVER to drill them! You can read the safety rules yourseld at magnets4less.com. These guys are the rare earth magnet gurus. I trust em, and like your ides for the mahogany veneer best. Good luck!
-- You don't have a custom made heirloom fly fishing Net? http://www.Sierra-Nets.com
View hhhopks's profile
hhhopks
654 posts in 2617 days
#9 posted 11-26-2012 11:55 AM
Magnets should be hard and very britle.
As you try to drill them out it is more likely that it will crack.
Good luck.
I think you best bet is to heat it up so that you can remove the magnet.
They do sell donut shape magnets (used all the time in wooden toy trains) that you could epoxy back in place.
-- I'll be a woodworker when I grow up. HHHOPKS
View Howie's profile
Howie
2656 posts in 3163 days
#10 posted 11-26-2012 12:14 PM
Would it be possible to soak it in acetone, then let the acetone dry after removal? I thought that was what you used to remove gorilla glue.
I would be careful trying to heat these magnets, possibly they could explode( JMHO don’t know for sure)
-- Life is good.
View EEngineer's profile (online now)
EEngineer
1119 posts in 3853 days
#11 posted 11-26-2012 12:18 PM
The truth is heat and magnets don’t go well the magnetism becomes lost with heat…
Ah, but the truth is that magnets don’t lose their magnetism until you hit the Curie Temperature. A quick look at Wikipedia shows that the lowest Curie temp for various magnetic materials is about 300-400 C. You aren’t going to get it that hot!
View HorizontalMike's profile
HorizontalMike
7770 posts in 3154 days
#12 posted 11-26-2012 12:19 PM
Just wondering here… Won’t these be hidden when in use? And if so, why not live with such a minor mistake? After all ALL of my pieces have mistakes and I know right where they all are, however others do not. They just admire the piece/project in its entirety. Just a suggestion.
View hg1027's profile
hg1027
40 posts in 2342 days
#13 posted 11-26-2012 12:31 PM
Could you put a piece of veneer over the whole thing?
DannyB
#14 posted 11-26-2012 06:09 PM
@EEngineer
Actually, magnets don’t begin to permanently lose their magnetism until they hit at least the curie temperature.
The curie temperature is actually the point at which all magnetism is lost but it can still be remagnetized (IE irreversible but recoverable). Somewhere above that, you get permanent losses.
See http://www.magmamagnets.com/permanent-magnet-stability and such.
However, between the max operating temperature, and the curie temperature, you get irreversible but recoverable losses. That is, if you cool it back to room temperature, it will have lost some magnetism, but it could be remagnetized back to normal.
The max operating temperature of neodymium magnets depends on the grade (and it’s a curve rather than a single point), but even for the highest grade of neodymium magnets, the max op temp is only ~130 celsius. My heat gun can easily produce that temp.
Jonathan
#15 posted 12-01-2012 02:09 PM
Thanks for all the input on my dilemma. I have decided that I’m going to cut a thin mahogany veneer to go over the back. I may just leave it like that to completely hide the magnets, instead of trying to cut more holes in the veneer, then filling with more epoxy.
