| Forum topic by Sabs | posted 174 days ago | 499 views | 0 times favorited | 11 replies | ![]() |
174 days ago |
I am considering building new cabinets for my house. I was previewing some cabinet building books at my local Menards store. To my suprise none of them recommended that I would need large Drum or Belt Sander, Planner, or a Shaper. I would like to build a very high quility constructed cabinet. Raised panel doors, dovetail drawers solid wood sides etc. Does anyone think this can be accomplished with a powerful quility Router, hand operated belt sander, and some planes. |
11 replies so far
#1 posted 174 days ago |
it can be accomplished with hand planes alone, a good router will obviously help. I’ve built a lot of cabinets, and never had a drum sander, and I don’t really see a need for a belt sander. If you plan on raising the panels with the router, you’ll need a router table. But you can also use hand planes or your table saw. There re several ways to accomplish this. I would say a good block plane is a must. Smooth the frames with a good smoothing plane. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#2 posted 174 days ago |
Sure it can. Table saw and router. Chisel and dovetail saw. Block plane and card scraper. Glue and clamps. That said, it’s an ambitious project and you will want to build the modules in the shop so as not to disrupt your life. If your kitchen is anything like mine, you are talking 40 doors and 25 drawers. That’s a lot of freaking work, especially if you plan on doing dovetails. I’d either use box joints with a jig or purchase something like Blum soft-close drawer slides where you just supply the back, bottom, and front panels. -- jay, www.allaboutastro.com |
#3 posted 174 days ago |
Can I raise the panels 1 1/2 to 2 1/2 from there edge with a standard router. Can get a nice smooth finish on the face of the panels with planes and some sand paper. |
#4 posted 174 days ago |
You’ll want a big router to spin the big panel raising bits, but you can do it with a regular router (like a 2.25 to 2.5 hp) if you take very small passes….which you’ll want to do anyway. You can also use vertical panel raising bits, where you pass the panel through on edge…these are easier to spin in regular routers. -- jay, www.allaboutastro.com |
#5 posted 174 days ago |
Mr. Cosmicsniper: I was accually thinking of doing my whole house that I built 15 years ago with modistly built cabinets. I just counted, and I have 37 raised panel cabinet doors, and a cobination of 52 raised panel or flat face drawer fronts. Any specific tool recommendations for a fairly big task. |
#6 posted 174 days ago |
Wow. Then I’d look into doing the dovetails mechanically, with either a commercial jig (like Akeda or Leigh) or a positioning fence (I use an Incra LS). This will help to mass-produce the drawer boxes. I’d also want a planer and jointer so that you don’t have to work with finished dimension stock from a big box store…too expensive. If your existing cabinets are also raised panels, I would consider reusing them. I did that for my kitchen, reprofiling the panels and using wider rails and stiles to compensate….which I wanted anyway. If you don’t have that, you will need a way to joint those boards to create the panels. A finely tuned table saw with glueline rip blade will do in lieu of a jointer. -- jay, www.allaboutastro.com |
#7 posted 174 days ago |
Look at what you’d consider a reasonable timeframe. That is a nice size project, especially if you’ve never built cabinets. If you have no time frame and someplace to work that many at one time, it will be a fun project and very rewarding. Would you rebuild the whole cabinet or just the doors? -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#8 posted 173 days ago |
All my current drawers are dovetail boxes with just a 1/4 bottom. As I mentioned earlier, they have decenent undermounted slides. The style of the cabinet fronts is a full overlay with a matching frame underneath. The drawers have no matching frame, they just close on the egdes of the plywood sides that are covered with a cheesy strip of melomine that no longer matches the aged natural cherry satin finish. I am not opposed to keeping all these solid cherry fronts, and drawer boxes. The real disapointment is the flush veneer exposed sides, that basically have no character and in some cases look weathered where the natural sun light has faded them. The overall design and theme is very modest with a beautifully warm amber color. I am in a location where I cannot over improve the property. I was thinking how I could justify buying a few thousand dollars of tools. I do have a pole building where I could take my time building this project. |
#9 posted 173 days ago |
You’re looking at frameless I think. You need a way to make |
#10 posted 173 days ago |
I was mistaken, my cabinet doors and drawers are all framless, with this no longer matching cheep melomine glued to the edges of all the plywood sides. I read in a book this weekend that cabinets with a flush frame around all the doors and drawers was represented as being the highest end quility and workmanship. Would you agree. I don’t how I can salvage my excisting doors and drawers with all the change in color from 13 years of sun exposure. |
#11 posted 173 days ago |
I would recommend a Festool saw and guide system to make good cabinets and one only has a small space.
-- Oldworld, Fair Oaks, Ca |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3541 |
15749 |
Hand Tools
2027 |
Jigs & Fixtures
493 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
