| Forum topic by Jeff82780 | posted 180 days ago | 960 views | 2 times favorited | 9 replies | ![]() |
180 days ago |
so i just made my first shooting board and i love it. I wish i would’ve built one sooner. But anyway, I am having one problem. 1. I shoot one side of long grain. 2. register that side on fence and shoot the end grani.3. i repeat and do the same sreps for the other side. the board comes out square except for end grain i shot in the first step to the long grain in the last step. ? Can anyone help. I checked the shooting board to make sure all is sqaure and it all is. Is a shooting only supposed to square 1 side? |
9 replies so far
#1 posted 180 days ago |
What are your diagonal measurements? |
#2 posted 180 days ago |
How are you registering the long grain on the second side? If you were to lay a framing square against the stop on the shooting board and register your good side to the square, you might be better off. Trying to register the long grain from the end grain against the stop would be nearly impossible. Normally shooting boards are used to square end grain. -- Made in America, with American made tools....Shopsmith |
#3 posted 180 days ago |
I believe you might need another shooting board for your edge grain. Something like this: http://www.lie-nielsen.com/pdf/Shooting_Board_And_Fixtures.pdf Rich;) -- Rich;) -"Dada make a big mess?" "Yes Dada made a big mess." |
#4 posted 180 days ago |
when measuring diagonals everything is perfect, but when i take a square to the board onlly 3/4 sides are square. when registering the long grain on the second side i use the end grain that i just shot. |
#5 posted 180 days ago |
Jeff, I use a shooting board ALOT. I never get the first long grain squared up on the shooting board (SB). I get it squared with a jointer plane and a long straight edge to make sure that edge is good to go. Once I have that done, I use the shooting board to square both end grain sides (using a square to ensure everything is correct. Once those are square, I will square up the other long grain side. Also, you must ensure your fence on the SB is square. ABSOLUTELY square. If not, it will cause an awful lot of aggravation (been there, done that!) Here is a pic of mine, it is a workhorse in my shop.
-- Mike |
#6 posted 180 days ago |
Jeff, You can’t have perfect diagonals and one corner out of square. I’m wondering if maybe you’re getting a rocking effect while planing that makes your sides not flat, try setting an straight edge on each side to see if everything is flat. If your end grain sections are short and the long grain sections longer, it will be hard to keep the end grain flat against the stop causing rocking and a less than flat surface. I would try long side, end, end, and then the last long side, possibly clamping or screwing a stop parallel to the plane direction to keep the board from pivoting. Good luck, |
#7 posted 180 days ago |
OK, I checked the checked the diagonals again an found out that i am a 32nd off square. This is so frustrating! I think i’ve tried everythiung. I tried jointing one edge first, then suaring both ends on the shooting board and shooting long grain., I checked everything, fence is square to the plane. I also made sure the board was absolutely flat so i would get no rocking motion . I even built another shooting board . Nothing has worked . |
#8 posted 177 days ago |
All you ever wanted to know about shooting boards … http://www.inthewoodshop.com/ShopMadeTools/Setting%20Up%20and%20Using%20a%20Shooting%20Board4.html http://www.inthewoodshop.com/ShopMadeTools/Advances%20in%20a%20ramped%20shooting%20board.html http://www.inthewoodshop.com/ShopMadeTools/ShootingforPerfection.html Rather than making a fixed fence, build a little fine adjustability into it. On a shooting board fence such as here ..
Make the far end bolt hole capable of a little movement back-and-forth.
Regards from Perth Derek -- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com |
#9 posted 101 days ago |
Paul Sellers shows how to make a Shooting Board |
| Forum | Topics |
Woodworking Skill Share
8798 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1537 |
3554 |
15806 |
Hand Tools
2039 |
Jigs & Fixtures
496 |
Wood & Lumber
2846 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2741 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6165 |
