| Forum topic by RussellAP | posted 178 days ago | 318 views | 0 times favorited | 5 replies | ![]() |
178 days ago |
Should I do those brass lower and upper corners on the back side as well as the front? -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
5 replies so far
#1 posted 178 days ago |
I always think of the brass corners as belonging to a trunk. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#2 posted 178 days ago |
If you’re going to use them, I’d use them all the way atround. -- Charlie M. "Woodworking - patience = firewood" |
#3 posted 178 days ago |
Is that base attached to the sides with the brass corners captured between the base and sides? If it is the later, then back corners would be appropiate. If the base is attached then none of the bottom corners seem appropiate to me. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#4 posted 178 days ago |
I’ll use them on the top and not the bottom, Crank49 is right. The base is enough there. And crank, I just filed one side of those corner brass pieces off and stuck them up there to see if I like them. Here is a picture after the first coat of Minwax wipe on poly.
#5 posted 178 days ago |
ditto a1Jim comment. -- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did. |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3549 |
15781 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
