Connecting dust collector hoses
Forum topic by JohnbNJ posted 11-24-2012 06:15 PM 3461 views 0 times favorited 16 replies Add to Favorites Watch
View JohnbNJ's profile
JohnbNJ
5 posts in 2034 days
11-24-2012 06:15 PM
Any tips on easy way to connect dust collector hose to fittings?
16 replies so far
4999 posts in 2518 days
#1 posted 11-24-2012 06:46 PM
Duct tape, wooden donuts, adapters (my last choice). You can also use HVAC and/or PVC fittings. The only hard/fast rule of DC ducting is that nothing fits….you have to improvise.
View RussellAP's profile
RussellAP
3104 posts in 2311 days
#2 posted 11-24-2012 07:03 PM
Harbor frieght has a good kit that goes with their DC. They give you lots of clamps.
View Alexandre's profile
Alexandre
1417 posts in 2215 days
#3 posted 11-24-2012 07:06 PM
Hose clamps?
-- My terrible signature...
JohnbNJ
#4 posted 11-24-2012 08:05 PM
I’m having difficulty getting the hose over the fittings. Any better way than brute force? soap, wax or hot water? Is there any easy way to shift hose from one tool to another? I don’t want to permantently secure to one amchine.
View Randy Woodworker's profile
Randy Woodworker
68 posts in 2354 days
#5 posted 11-25-2012 12:01 AM
”Is there any easy way to shift hose from one tool to another? I don’t want to permantently secure to one amchine.”
Slip on Connector
View Kreegan's profile
Kreegan
1452 posts in 2171 days
#6 posted 11-25-2012 01:44 AM
I have heard silicone spray lubricant is good for this purpose. I’m having the same problem with my new Harbor Freight 2HP dust collector, so I’ll test it out and get back to you.
Rich;)
View bullhead1's profile
bullhead1
228 posts in 2273 days
#7 posted 11-25-2012 02:04 AM
Rockler has a hose system with a an expandable flex hose with a handle to move from machine to machine. Be careful, by the time you buy the hose and all the fittings it may be more cost effective to run lines to all your machines with blast gates.
View derosa's profile
derosa
1577 posts in 2860 days
#8 posted 11-25-2012 02:27 AM
http://www.woodcraft.com/product/2000899/9177/4-quick-disconnect-hose-to-4-od-dust-collection-fitting.aspx
I have the gate that ryanira posted on my dust collector although that wasn’t too necessary since the hose could just be muscled onto there but since I wanted a gate that seems like the best option. What I’ve posted sits at the other end of the hose and I believe is the solution you want. My hose required a ton of effort to get onto the tablesaw an I never managed to fit it on the dewalt planer. This attachment slips right inside and stays snug. Hasn’t dropped out of the table saw or slipped out of the planer yet.
-- --Rev. Russ in NY-- A posse ad esse
View pmayer's profile
pmayer
1028 posts in 3090 days
#9 posted 11-25-2012 02:35 AM
If you are using PVC, you can use standard PVC couplers as a great quick disconnect system. The flex hose slips in on one end, and make your own port for your tool using PVC pipe, and the coupler slips right over that. Look toward the bottom of this article for pictures of this: https://www.wwgoa.com/articles/projects/-d-o-g-simple-approach-for-dust-collection-ducting/
I use these on several tools in my shop and they really work great. If the flex doesn’t fit tightly in the couple you could tape it in place, but I haven’t had any problems, especially with the 6” flex.
View Gerry's profile
Gerry
264 posts in 3265 days
#10 posted 11-25-2012 02:39 AM
I have had the same issues and found a combination solution.
Using both the std 4” hose fittings and the 4” white sewer pipe fittings together with a liberal
amount of an inexpensive hardening caulk has done the job. Fitting the two systems together
takes some trial and error but if you can get them close, the caulking makes
the fit. The key is to find fittings from both systems that will fit into each other loosely.
Once assembled, caulked and cured you have what you need to join the two types of pipe.
I have used this successfully for my whole shop.
Hope this is of help. Cheers!
-- -Gerry, Hereford, AZ ” A really good woodworker knows how the hide his / her mistakes.”
runswithscissors
2764 posts in 2050 days
#11 posted 11-26-2012 05:01 AM
I have no idea why the male fittings for ductwork aren’t a uniform (and correct) size. I recently had a situation where the coupling was a struggle to put on or take off, but the el fitting was an easy slip on. From the same vendor. To make the coupling work reasonably well, I sanded one end to a smaller diameter by rotating against my 6 inch stationary belt sander. Worked okay. I only reduced one end, as the other could stay put.
For quick switch over from one machine to another, an annoyance is having to loosen and tighten hose clamps. I cut standard 4” hose clamps, and rivet the 2 parts of a draw latch onto the resulting ends. Now I can quickly and easily swap between machines. I leave the adjusting screw in place, so the clamp can be fine tuned to the variable diameter fittings. I’m even thinking of wiring the clamps onto the ends of duct hose that gets swapped pretty often, so they don’t drop off while the tension is released during transition.
View mbs's profile
mbs
1656 posts in 2965 days
#12 posted 11-26-2012 05:34 AM
It depends on the hose you buy and the fittings you use.
The real heavy duty grey hose won’t fit over Sewer and drain pipe but Woodstock makes a quick disconnect threaded blast gate that fits on your 4” dust port connections. You simply screw it into your hose and put a hose clamp on it. here is a pic.
There are also threaded quick disconnects that don’t have a blast gate.
If you have the clear hose and S&D pipe I’ve always been able to get it on the fittings without the aid of any soap….
-- Sorry the reply is so long. I didn't have time to write a short reply.
View toolie's profile
toolie
2134 posts in 2653 days
#13 posted 11-27-2012 01:27 AM
i had the same problem recently getting someo flex of the 6 X (2) 4” adapter of my delta 50-850. i used a hair dryer to heat the flex adn it slipped onto the adapter quite easily. i used to use pots of hot water. the hair dryer is MUCH better. when i want to remove the flex from the adapter, i just heat it with the hair dryer and it slips off easily.
JohnbNJ
#14 posted 12-06-2012 12:05 AM
Folks,
Thanks for all the replies. Stupid didn’t write dow my user id and password. Just figured it out. I was hoping to avoid blast gates etc and shift hose between machines. some interesting ideas I’ll investigate. Thanks again.
John
View Elizabeth's profile
Elizabeth
817 posts in 3168 days
#15 posted 12-06-2012 12:14 AM
I used to use the Rockler system mentioned upthread (It’s called Dust Right, here are some of the items ) before I had my permanent system put in. I connected my portable dust collector to the handle and put the ports on my tools. It worked well and it was easy to move from tool to tool. If you decide to go this route, I am no longer using the parts that I bought and could sell them to you for less than new cost. I have the handle, a handful of 4” ports and I think two 2.5” ports. Send me a message if you’re interested.
