who needs a biscuit joiner?
Forum topic by bigbullets posted 11-24-2012 03:47 PM 1399 views 0 times favorited 8 replies Add to Favorites Watch
View bigbullets's profile
bigbullets
25 posts in 2110 days
11-24-2012 03:47 PM
Topic tags/keywords: biscuit joiner question joining
I am in the middle of building a library stand and coming down to the end of it where i have to glue up the 24×18 table top. now the plan dont call to do it with biscuits, but i am not entirely sure if using biscuits will in the long run keep the glue joints from separating. do you really need a biscuit joiner for this type of glue up?
-- "good night Chesty Puller, where ever you are"
8 replies so far
5013 posts in 2543 days
#1 posted 11-24-2012 03:50 PM
I’m not one to poo-poo biscuits, I think they really have their uses. However, one of them is NOT edge to edge long grain. Other than alignment, which is useful, they add little to those joints IMHO.
View Bob Kollman's profile
Bob Kollman
1798 posts in 3240 days
#2 posted 11-24-2012 03:55 PM
Biscuits add more glue surface and make your joint stronger. It is a small surface and as a library stand I think you can get away without biscuits.
-- Bob Kenosha Wi.
bigbullets
#3 posted 11-24-2012 03:56 PM
thanks Fred! I know the alignment was the main feature but strengh was wasnt sure of. maybe I will use some dutchmen
View johnstoneb's profile
johnstoneb
2965 posts in 2222 days
#4 posted 11-24-2012 04:34 PM
I use biscuits mainly for alignment. They will add a little to the strength but on an edge to edge joint you don’t need them for strength.
-- Bruce, Boise, ID
View MonteCristo's profile
MonteCristo
2099 posts in 2238 days
#5 posted 11-26-2012 05:10 AM
In your case biscuits are simply an alignment aid. The glue joint, if properly done, is stronger than the wood.
View mbs's profile
mbs
1657 posts in 2990 days
#6 posted 11-26-2012 05:27 AM
I can’t say I hate biscuit joints but I will say that I own a biscuit jointer that hasn’t been used in probably 15 years.
I prefer dowels, splines, and mortise/tenon for alignment and strength. I never found the biscuits to be that helpful with alignment.
-- Sorry the reply is so long. I didn't have time to write a short reply.
View knotscott's profile
knotscott
8078 posts in 3425 days
#7 posted 11-26-2012 10:31 AM
I thought I needed them when I was a rookie and didn’t know any better. I sold my biscuit cutter…on the rare occasions I think biscuit will help, I cut the slot with a router.
View mountainaxe's profile
mountainaxe
149 posts in 2555 days
#8 posted 11-26-2012 12:53 PM
I’ve used biscuit joiners quite often with good results. Not sure why there’s such a negative vibe about this tool. I agree that it’s useful for alignment purposes, but it also adds quite a bit of strength to the joint. Although it’s rather eyeglazing, there’s an interesting article on the web that conducted some experiments and goes into great detail claiming “that the “as tested” biscuit joints had as much as 80 percent of the strength of a mortise and tenon joint.” http://www.woodworking.org/WC/GArchive98/Abstract/abstract1.html. That’s pretty impressive for such a simple procedure and sure warrants consideration.
-- Jeff, "The things I make may be for others, but how I make them is for me."
